OSError: no available NIC after Soft-Reset
  • Hello,
    i have a problem, hopefully you can help me.
    After a soft-reset (CTRL-D in REPL), i get the error that there is no available NIC when using the urequest.post command. After a hard-reset everything is working fine.
    Propably the re-initialization of the wifi interface is not done right?
    boot.py
    import os
    from network import WLAN
    import urequests
    uart = machine.UART(0, baudrate=115200)
    os.dupterm(uart)
    wlan = WLAN()
    if machine.reset_cause() != machine.SOFT_RESET:
    	print('Init Wlan',end='')
    	wlan.mode(WLAN.STA)
    	print(' done')
    if wlan.isconnected():
    	print('Already connected to WiFi network.')
    		print(wlan.ssid())
    	nets = wlan.scan()
    	net_to_use=[]
    	pw=[]
    	for net in nets:
    		if net.ssid =='Malle16':
    			net_to_use=net
    			pw='123456'
    	if net_to_use==[]:
    		for net in nets:
    			if net.ssid =='FRITZ!WLAN Repeater N/G':
    				net_to_use=net
    				pw='123456'
    	if net_to_use==[]:
    		for net in nets:
    			if net.ssid =='Outdoor':
    				net_to_use=net
    				pw='456'
    	wlan.connect(net_to_use.ssid, auth=(net_to_use.sec, pw), timeout=10000)
    	while not wlan.isconnected():
    		time.sleep_ms(500)
    		print('.', end='')
    	print(' connected.')
    print("IP address: " + wlan.ifconfig()[0])
    print('-----------------------------')
    print('boot.py finished')
    machine.main('main.py')
    main.py
    	payload="status,volk={0} wert={1:0.2f} {2}".format(Volk_Nummer,Status,t)
    	response = urequests.post(db, data=payload)
    	print('---- Influxdb Update OK ----')
    	time.sleep(20
