    Lopy with modbus
    9 Posts 5 Posters 689 Views 5 Watching
      abhishek2101
      Which pins do I need to connect on the board to do modbus ?
        abhishek2101 @abhishek2101
        can anybody help please ?
        • E Offline
          Eric73
          Hi, in fact it's depends if you do modbus over tcp (so it's wifi and no pin) or modbus RTU using uart pin (and RS232/RS485 transceiver don't use directly your uart pin!) you have selected when you created your modbus object.
          According to source code this is an valid example.
          uart_id = 0x01
          modbus_obj = Serial(uart_id, pins=('P9', 'P10'))
          It's seem that pycom documentation lake information about the initialization of this object
            abhishek2101 @Eric73
            @Eric73 I will be using Modbus RTU, can you suggest me a good RS485/RS232 transceiver ?
            • E Offline
              Eric73 @abhishek2101
              @abhishek2101 RS485 OR RS232 it depend of your sensor.
              MAX3232 or SN65HVD10 for exemple is good component.
                svonbentzel
                can I connect the modbus device directly to the Pycom Board.
                or did I need a additional modus RS485 adapter?
                E T 2 Replies Last reply Reply Quote 0
                • philwilkinsonP Offline
                  philwilkinson
                  Have anyone had success with this modified modbus library?
                  • E Offline
                    Eric73 @svonbentzel
                    @svonbentzel No, i dont know witch which pycom board your talking about, but ESP32 RX/YX pin are 3.3V TLL level, modus is RS422 or RS485 or RS232. RS422 and RS485 are very close electrical level (on a differential line), RS232 is +12V and -12V so you need an adapter and you must choise it to be on same physical level of the sensor you plan to use.
                      thibault @svonbentzel
                      @svonbentzel No, for me too. I have use this one for get modbus run fine:
                      github.com/pycom/pycom-modbus/tree/master/uModbus
