    WiPy -> AM2315 env sensor - I2C interface
    2 Posts 2 Posters 985 Views 2 Watching
    • K Offline
      Kevin Hanna
      Has anyone successfully interfaced to the AM2315 temp / humidity sensor?
      If so what modules did you use?
      kevin Hanna
        livius
        this is really simple sensor I2C
        you can change code to python
        oolean Adafruit_AM2315::readData(void) {
          uint8_t reply[10];
          // Wake up the sensor
          Wire.beginTransmission(AM2315_I2CADDR);
          delay(2);
          Wire.endTransmission();
          // OK lets ready!
          Wire.write(AM2315_READREG);
          Wire.write(0x00);  // start at address 0x0
          Wire.write(4);  // request 4 bytes data
          delay(10); // add delay between request and actual read!
          Wire.requestFrom(AM2315_I2CADDR, 8);
          for (uint8_t i=0; i<8; i++) {
            reply[i] = Wire.read();
            //Serial.println(reply[i], HEX);
          if (reply[0] != AM2315_READREG) return false;
          if (reply[1] != 4) return false; // bytes req'd
          humidity = reply[2];
          humidity *= 256;
          humidity += reply[3];
          humidity /= 10;
          //Serial.print("H"); Serial.println(humidity);
          temp = reply[4] & 0x7F;
          temp *= 256;
          temp += reply[5];
          temp /= 10;
          //Serial.print("T"); Serial.println(temp);
          // change sign
          if (reply[4] >> 7) temp = -temp;
          return true;
        float Adafruit_AM2315::readTemperature(void) {
          if (! readData()) return NAN;
          return temp;
        float Adafruit_AM2315::readHumidity(void) {
          return humidity;
