    Sending MAC layer commands
    lorawan
    3 Posts 2 Posters 291 Views 2 Watching
      thinginnovations
      I'm going throungh the LoRa API documentation at https://docs.pycom.io/firmwareapi/pycom/network/lora.html and cant see anywhere I can set MAC layer commands other than the battery level.
      What I'm looking for is the link check interface in order to determine link quality and force a re-join if needed.
      I've used this effectively on other devices where I can set a link check frequency and failure threshold. This looks to be lacking in the python layer.
      Any timescales on this being implemented or a workaround to access the MAC layer through the python interfaces?
      thanks
      Andrew
      • E Offline
        Eric73
        Lopy is a device and not a gateway, so it's only receive MAC command from gateway (linkaddrreq). Lopy lorawan revision is 1.02, and MAC command to force a rejoin from a gateway is only in 1.1 lorawan rev.
        You have use lora.stats() to implements your rule :
        -check rssi, snr, used datarate from the latest downlink received is good enought for you or if your board have to do a forced rejoin
        -If you haven't a downlink from the time you have set , force a rejoin...
        and so on....
        The lora.set_battery_level(level) is an automatic response you set before the gateway send to your device the request, it doesn't send anything by himself before the gateway ask for it.
          thinginnovations
          I know this is not a gateway. I have been using other devices where I am able to send MAC layer commands. Your response fails to answer any of this.
          Andrew
