    LoPy: bytes data received in HEX convert to original text
    1 Posts 1 Posters 283 Views 1 Watching
      pkilcoyne
      To whom it concerns,
      I'm sending LoRa messages from an Adafruit Radio bonnet to a LoPy4 but the message received seems to be in Hex -
      Adafruit Radio bonnet with the following settings:
      # Configure LoRa Radio
      CS = DigitalInOut(board.CE1)
      RESET = DigitalInOut(board.D25)
      spi = busio.SPI(board.SCK, MOSI=board.MOSI, MISO=board.MISO)
      rfm9x = adafruit_rfm9x.RFM9x(spi, CS, RESET, 869.85) # freq = 869.85mHz
      rfm9x.tx_power = 23
      rfm9x.spreading_factor = 12
      rfm9x.signal_bandwidth = 125000
      rfm9x.preamble_length = 8
      when button "A" is pressed "Hello" is transmitted as follows:
      button_a_data = bytes("Hello","utf-8")
              rfm9x.send(button_a_data)
      On the LoPy4 set up as follows:
      lora = LoRa(mode=LoRa.LORA, region=LoRa.EU868, sf=12, frequency=869850000, bandwidth=LoRa.BW_125KHZ, public=False, preamble=8, coding_rate=LoRa.CODING_4_5, tx_iq=False, rx_iq=False, power_mode=LoRa.ALWAYS_ON, tx_power=14)
      s.setblocking(False)
      raw_data = s.recv(32)
      if len(raw_data) != 0:
         print('RX: data received')
              print(len(raw_data))
              print(type(raw_data))
              print(raw_data)
              data = raw_data.decode("utf-8")
              print(type(data))
              print(data)
      The LoPy receives the "Hello" from the Adafruit Radio Bonnet as follows:
      RX: data received
      data length: 9
      data type: <class 'bytes'>
      data: b'\xff\xff\x00\x00tO+\xf1\x80'
      In the above code I attempt to convert bytes to string:
      data type: <class 'str'>
      string data: ��tO+�
      RSSI: -126, SNR: -7.0
      How should I interpret the raw data received and convert it back to the original "Hello" transmitted?
      Thank you,
      Paul
