    OSError
    3 Posts 3 Posters 237 Views 3 Watching
      Lucas_Vieira
      Hi, guys. I have a problem in my code. I'm using Atom. Can you help me?
      from machine import Pin
      p13 = Pin('P13',mode=Pin.IN)
      p14 = Pin('P14',mode=Pin.IN)
      p15 = Pin('P15',mode=Pin.IN);
      p16 = Pin('P16',mode=Pin.IN)
      p18 = Pin('P18',mode=Pin.IN)
      if p13.value() == False:
          for cycles in range(1):
              pycom.rgbled(0x0000FF)
              #print('Nivel esta em 1 metro a cima do rio!')
              time.sleep(.8)
              time.sleep(.8)
      if p15.value() == False:
              pycom.rgbled(0xcFFFF00)
              #print('Nivel esta em 3 metros a cima do rio!')
              time.sleep(.8)
              time.sleep(.8)
      if p16.value() == True:
              pycom.rgbled(0xff0000)
              #print('Nivel esta em 4 metro a cima do rio!')
              time.sleep(.8)
              time.sleep(.8)
      if p18.value() == False:
          for cycles5 in range(1):
              pycom.rgbled(0xFF00FF)
              #print('Esta chovendo no rio!')
              time.sleep(.8)
              time.sleep(.8)
      I'm being notified with the error:
      File "main.py", line 25, in <module>
      OSError: the requested operation is not possible
      Line 25 is ->pycom.heartbeat(False) of the condition p15.
      • K Offline
        kjm
        You have to turn off the default heatbeat before you can use the RGB led
          alexen
