Use Battery (Pull P8 high)
  • To boot from the battery on the Expansion Board v3.0 I understand that you have to pull P8 high. I tried this using the following code:
    from machine import Pin
    pin=Pin('P8',Pin.OUT)
    pin.value(1)
    print(pin.value())
    but that does not seem to have any effect. Do you know what is wrong with the code?
  • @max You have to pull up P8 physically, because that sensing is done before MicroPython gets active.
