    Software reliability
    gpynetworklte
    4 Posts 3 Posters 330 Views 3 Watching
    • K Offline
      kjm
      Can anyone explain to me why
      from network import LTE; lte=LTE()
      would be more reliable & less like to generate a
      NameError: name 'lte' is not defined
      later in the program than
      import network; lte=network.LTE()
      robert-hhR C 2 Replies Last reply Reply Quote 0
        robert-hh @kjm
        @kjm There is no difference between the two options. If you see one, check whether there is a difference in the scope of lte symbol, like global vs. local. A global symbol can be seen everywhere in the code, but creation or assignment in a function or class is local, unless you define it explicitly as global.
          crumble @kjm
          @kjm
          Hard to tell without more details.
          Do you import all your stuff at the beginning or somewhere inside the script?
          • do you really reach the declaraiont path?
          • have you checked for try/catch?
          • checked memory fragmentation?
          • checked that callbacks will be handeled only after the declaration
          • K Offline
            kjm
            I think I might have a flash memory problem, something that has haunted me with GPYs from the getgo. If I upload then remove then upload boot.py & main.py several times I seem to get a more stable system. It's like the first write of new software is not enough.
