Expansion Board 3.0 Vin (3.5-5.5V) pin
  • Hi all,
    A quick question: is the voltage of the Expansion board 3.0 5V pin the same as the power supply voltage (3.5-5V) or is it always 5V, regardless of input? On the Expansion board 3.0 pinout, it's marked as 5V but on the LoPy4 pinout, it's Vin (3.5-5.5V).
    In other words, is the input voltage regulated in any way on the expansion board?
    Thanks!
  • Global Moderator
    @KiraKiraSoul said in Expansion Board 3.0 Vin (3.5-5.5V) pin:
    No. It's the same signal, just differently labeled. When connected to USB, you should see 5V at that pin coming from USB. Otherwise you can supply a xxPy device at that pin with input voltages from 3.5-5.5 V.
