    Using RTC DS3231
    4 Posts 4 Posters 360 Views 4 Watching
      Lucas_Vieira
      Hi, guys. i need your help. i'm using a RTC DS3231 and i have this problem:
      I'm having this problem because of the least significant bit overflow?
      what kind of function could I apply to fix this problem?
      (00h address of seconds)
      I would like to ream from 0-59s in integer. Thank you for your supp!
      • E Offline
        Eric73
        So, your trouble is second RTC register is in BCD format.
        Something like this in line 18
        sec=(seg&0xF0)*10+seg&0x0F
        print(sec)
        will give you the correct int value
          robert-hh @Lucas_Vieira
          @Lucas_Vieira @Eric73 Actually it should (could) be:
          sec = (segundos[0] >> 4) * 10 + (segundos[0] & 0x0f)
          or
          sec = (segundos[0] // 16) * 10 + (segundos[0] & 0x0f)
          The conversion to seg is not needed, since array access to a single bytearray element returns an integer.
          • E Offline
            Elizar
            '\t' is the same code as '\x09', see https://theasciicode.com.ar/ascii-control-characters/horizontal-tab-ascii-code-9.html
