    UV sensor
    5 Posts 2 Posters 362 Views 2 Watching
    • Q Offline
      quentho
        robert-hh @quentho
        @quentho I understand the data sheet that the output is an analog value, expected in the range of 0-~3V. 0V without UV light. Did you apply UV light to the sensor?
        Q 1 Reply Last reply Reply Quote 0
        • Q Offline
          quentho @robert-hh
          @robert-hh i use this code :
              adc = machine.ADC()
              apin = adc.channel(pin='P16')
              val=apin.value()
              print("UV:",val)
            robert-hh @quentho
            @quentho That should work. P16 on SiPy is not used for something else. I assume that you powered the sensor and applied it to UV light.
            • Q Offline
              quentho @robert-hh
              @robert-hh thank you it's working
