    bit concatenate
    5 Posts 4 Posters 384 Views 4 Watching
    • Q Offline
      quentho
      hello,
      i would like to concatenate 4 sensor values to create bytes to send via sigfox.
      exemple :
      capt1 =0b1001010001110010101110
      capt2=0b10111011101111101001110
      capt3=0b0
      capt4=0b1010010
      i would like :
      temp=0b1001010001110010101110 10111011101111101001110 0 1010010
      (capt1) (capt2) (capt3) (capt4)
      i try with two but it's not working
      this is my code :
      class tools:
          def trame(capt1,capt2,capt3,capt4):
              temp = ((capt1 << 23) | capt2)
              print(capt1)
              print(capt2)
              result=hex(temp)
              return  result
      and the error :
      TypeError: unsupported types for : 'str', 'int'
      on this line :
      thank you
      E robert-hhR 2 Replies Last reply Reply Quote 0
      • E Offline
        Emmanuel Florent @quentho
        @quentho you can try with:
                result = (capt1 << 22) | capt2
                result = (result << 1 ) | capt3
                result = (result << 7) | capt4
                return  result```
        • Q Offline
          quentho
          I resolve my probleme, it was the bin function that returns a string of characters and not a binary number
          thank you for your answer.
            robert-hh @quentho
            • rcolisteteR Offline
              rcolistete
              See also the BitString module for MicroPython.
