    PyBytes + EXT_ANT
    5 Posts 2 Posters 368 Views 2 Watching
      sylvainm
      Good morning
      I am currently trying to set the Wifi Antenna as external with the PyBytes config.
      I added "wlan_antenna": 1 in the pybytes_config.json.
      wlan.antenna() result is 1 but the Pin('P12') give Pin('P12', mode=Pin.IN, pull=None, alt=-1).
      As the doc for ext_ant it should be Pin.OUT. Maybe I miss something in the config.
      Thank you
      Br
        robert-hh @sylvainm
        @sylvainm Please tell us:
        • which device are you using
        • which firmware version
          sylvainm
          Hi @robert-hh
          I am using Wipy 3.0 running FW 1.18.2.r6
          Thanks for reply
          Br
            robert-hh @sylvainm
            @sylvainm OK. So P12 should be indeed the antenna switch pin. Can you test the voltage at the Pin?
            I recall that there was a bug, causing P12 not set to output mode on init. So you can do that in your code. But that was fixed in Nov. last year:
            Author: iwahdan88 <islam@pycom.io>
            Date:   Thu Nov 8 18:35:10 2018 +0100
                esp32/util: fixed problem in antenna switch in newer esp32 chip models
              sylvainm @robert-hh
              @robert-hh
              Thanks , I ll test asap, and add in my code P12 as Pin.OUT.
              Br
