UART Issues
  • I am trying to read NMEA strings over UART, I can get this working fine however after a period of time I get a NoneType when running com.readline().
    Code to reproduce the problem is below.
    from machine import UART
    from time import sleep_ms
    # Setup comms to the GPS
    # G11 to GPS Rx
    # G24 to GPS Tx
    com = UART(1, baudrate=9600, bits=8, parity=None, stop=1,pins=("G24","G11"))
        print(com.readline())
        sleep_ms(1000)
    It would appear that sending data over UART0 causes partial or complete NMEA strings to be printed. I am wondering if this is a buffer problem or interference?
    Running gpstest.py
    Soft resetting the LoPy
    None
    None
    b'00329.3998,W,0.07,23.12,170117,,,D*48\r\n'
    b'$GPVTG,23.12,T,,M,0.07,N,0.14,K,D*08\r\n'
    b',20,26,03,050,*4B\r\n'
    b'$GPRMC,101354.000,A,5042.5075,N,8,48.3,M,50.4,M,0000,0000*4F\r\n'
    b'$GPGS48\r\n'
    b'$GPGGA,1009\r\n'
    LoPy details below:
    (sysname='LoPy', nodename='LoPy', release='1.3.0.b1', version='v1.8.6-379-gc44ebac on 2017-01-13', machine='LoPy with ESP32')
    Any help greatly appreciated.
  • Hi,
    I'm also experiencing this exact same problem with a Sipy and expansion board. Has there been any solution/reason to this issue?
    Using an external GPS but of the same brand type that is on the Pytrack (mine is the l80). Using the same speed and pins as the original poster.
    Sipy and Expansion board have both been upgraded to the latest firmware.
  • @PeterBaugh Did you check on f/w 1.4.0.b1 ?
  • @PeterBaugh Hi!
    I'll investigate this issue asap. Thanks for the report.
    Cheers,
    Daniel
