Unexpected WiPy ADC values
I'm getting an unexpected reading from the ADC.
When I connect the ADC input to GND and read it I see a count of 0 and a voltage of 54mV (with 0dB attenuation) or a voltage of 110mV with an attenuation of 11dB.import pycom import machine pycom.heartbeat(False) adc = machine.ADC() apin = adc.channel(pin='P13',attn=adc.ATTN_11DB) print ("Count:",apin()," Voltage:",apin.voltage())This prints:
Count: 0 Voltage: 110The displayed voltage varies with different attenuation. viz:
54mV for 0dB, 60mV for 2.5 dB, 82mV for 6dB and 110mV for 11dB. In all cases the count is 0.
Why is the voltage not also 0mV in all cases? -
@Jonno Below ~60 mV, the reading is 0. Therefore, all 0 values are mapped to that value. About the ESP32/WiPy ADC you may look at that analysis: https://github.com/bboser/IoT49/blob/master/doc/analog_io.md
Thanks @robert-hh . OK I see that the ESP32 ADC is less than perfect but not sure I understand why a count of 0 would give a adc.voltage() reading of non-zero.
Perhaps I should just read the count and do the conversion to voltage myself withcount * Vref / 4096and not use the
adc.voltage() option. -
@Jonno That conversion is the heart of the adc.voltage() code. But consider that the adc.value() will return 0 for any input voltage below ~60mV. So if you read 0, you only know that it's below 60mV. And Vref is slightly different for each device.
