    Run script on boot for LopY
    9 Posts 3 Posters 4.0k Views 3 Watching
      gouao
      My wish is to run a script on the boot of the LoPy, when I plug it in USB for example, without any action of the user.
      The LoPy is not running boot.py file when it is plugged to a power source ? What is the best way to do ?
      All the best.
        livius @gouao
        @gouao
        sequence is as follow:
        1. you plug power
        2. boot.py
        3. main.py
          gouao @livius
          @livius said in Run script on boot for LopY:
          @gouao
          1. you plug power
          2. boot.py
          3. main.py
          Sure, so the lopy should run boot.py and main.py after plugging power.
          But it doesn't
          • I Offline
            iber
            @gouao if the board isn't behaving as it should, best thing to do is reflash the latest firmware.
              livius @gouao
              @gouao
              can you conect to it by COM - e.g. by putty
              and send os.uname()?
              If yes then it run boot.py (if you have it default)
                livius
                I suppose that you modify boot.py and have error inside
                then you do not know that it is tried to run without succesfull
                better is to put something in main.py
                then you can see output about error in UART repl - e.g. in putty
                  gouao @livius
                  @gouao
                  There you go :
                  "(sysname='LoPy', nodename='LoPy', release='1.3.0.b1', version='v1.8.6-379-gc44eb ac on 2017-01-13', machine='LoPy with ESP32')"
                    livius @gouao
                    @gouao
                    as you can see your boot file was run - because you have repl
                    did you try my advice from second post - to put code not to boot.py only inside main.py and see if you do not got script error?
                      gouao @livius
                      @gouao
                      Only the COM commection argumens in the boot.py, and the script in main.py.
                      What the sync is really doing on the project ?
