    PyTrack dead?
    2 Posts 2 Posters 144 Views 2 Watching
      gunnar
      Hi! I just wanted to start using my new PyTrack/Gpy. As I understand I should update the Firmware first, right?
      But when connecting the PyTrack via USB it's not detected as a usb-device. No sign of life. Tested with two macs.
      Any idea? Should I get a new one (PyTrack ;-)
      Kind regards,
      Gunnar
      • R Offline
        rskoniec @gunnar
        @gunnar
        • Did you try with another USB cable?
        • Are you sure that you're using USB data cable not just charging USB cable?
        • Is there any dev file like /dev/tty.usb* after you connect PyTrack? (use Teminal to check that out)
        • Try on Windows machine maybe.
