    Buffer too small problem LoRa Lopy 4
    6 Posts 2 Posters 560 Views 2 Watching
    • F Offline
      ferfersan6
      Hey all. Maybe it is a very simple question, but I am very newbie with Python and Pycom. I am trying to send a simple doube with LoRa, from one Lopy 4 to other Lopy 4. I try to unpack the message on the receiving Lopy with struct.unpack('d',recpaquete), but it says the buffer is too small. I put the code:
      from network import LoRa
      import struct
      lora = LoRa(mode=LoRa.LORA, frequency=863000000)
      s.setblocking(False)
          recpaquete = s.recv(64)
          numero = struct.unpack('d',recpaquete)
          time.sleep(5)
      I have tried with several numbers (512, 1024, 2048...) but doesn't work. This Lopy just receive dates.
      The code from the other lopy is:
          paquete = struct.pack('d',57.3)
          s.send(paquete)
          time.sleep(5)
      Hope you can help me. Thanks in advance!!
        robert-hh @ferfersan6
        @ferfersan6 said in Buffer too small problem LoRa Lopy 4:
        How long is the message you actually receive? Tell it by
        print(len(recpaquete))
        It should be 8 bytes.
        F 1 Reply Last reply Reply Quote 0
        • F Offline
          ferfersan6
          • F Offline
            ferfersan6 @robert-hh
            @robert-hh I can't even receive a message, can't run or upload it on the Lopy. The error is in the title: "Buffer too small"
              @ferfersan6 The socket is set non noblocking. So s.recv() returns immediately if nothing was received. The return value is b"", with a buffer size of 0. Since the unpack requires at least 8 bytes, you get an error. So you have to add something like:
              import struct
                  if len(recpaquete) >= 8:
                  time.sleep(5)
              F 1 Reply Last reply Reply Quote 1
              • F Offline
                @robert-hh Wow, it works!!!! Thank you man, you are my hero!!. Seriously, I am so grateful.
