LoPy4 Nano-Gateway: no push/pull of ACKS
  • I have been digging this issue for a while, including this forum, google, etc, but getting nowhere.
    • I registered the LoPy4 device in TTN
    • I registered another LoPy4 device (connected to PyTrack Expansion board) as Nano-Gateway.
    First, I need to fix the issue with gateway - it is not push/pull acks at all and I am not sure why...
    Config.py
    #!/usr/bin/env python
    # Copyright (c) 2019, Pycom Limited.
    # This software is licensed under the GNU GPL version 3 or any
    # later version, with permitted additional terms. For more information
    # see the Pycom Licence v1.0 document supplied with this file, or
    # available at https://www.pycom.io/opensource/licensing
    """ LoPy LoRaWAN Nano Gateway configuration options """
    import ubinascii
    #WIFI_MAC = ubinascii.hexlify(machine.unique_id()).upper()
    # Set  the Gateway ID to be the first 3 bytes of MAC address + 'FFFE' + last 3 bytes of MAC address
    GATEWAY_ID = "ca11ab1e" #WIFI_MAC[:6] + "FFFE" + WIFI_MAC[6:12]
    print("Gateway ID: %s" % GATEWAY_ID)
    # I cannot ping neither to this router nor to router.eu.thethings.network
    # I tried to use my local router 192.168.1.1 but the results are the same...
    SERVER = 'router.us.thethings.network'
    PORT = 1700
    NTP = "pool.ntp.org"
    NTP_PERIOD_S = 3600
    WIFI_SSID = 'zzzzzzzzzzzzzz'
    WIFI_PASS = 'zzzzzzzzzzzzzzzzzzz'
    # for EU868
    #LORA_FREQUENCY = 868100000
    #LORA_GW_DR = "SF7BW125" # DR_5
    #LORA_NODE_DR = 5
    # for US915
    # I tried both US frequencies - no difference...
    LORA_FREQUENCY_9039 = 903900000
    LORA_FREQUENCY_9151 = 915100000
    LORA_GW_DR = "SF10BW125" # DR_0
    LORA_NODE_DR = 4
    main.py
    """ LoPy LoRaWAN Nano Gateway example usage """
    import config
    from nanogateway import NanoGateway
    if __name__ == '__main__':
        nanogw = NanoGateway(
            id=config.GATEWAY_ID,
            frequency=config.LORA_FREQUENCY_9039,
            datarate=config.LORA_GW_DR,
            ssid=config.WIFI_SSID,
            password=config.WIFI_PASS,
            server=config.SERVER,
            port=config.PORT,
            ntp_server=config.NTP,
            ntp_period=config.NTP_PERIOD_S
        nanogw.start()
        nanogw._log('You may now press ENTER to enter the REPL')
        input()
    I did not change nanogateway.py except this (added the region):
    self.lora = LoRa(
                mode=LoRa.LORA,
                region=LoRa.US915,
                frequency=self.frequency,
                bandwidth=self.bw,
                sf=self.sf,
                preamble=8,
                coding_rate=LoRa.CODING_4_5,
                tx_iq=True
    ...and yet, I get the following and no push/pull of ACK is being seen:
    Gateway ID: ca11ab1e
    [ 972.280] Starting LoRaWAN nano gateway with id: ca11ab1e
    [ 977.101] WiFi connected to: SoftDev
    [ 977.105] Syncing time with pool.ntp.org ...
    [ 983.261] RTC NTP sync complete
    [ 983.277] Opening UDP socket to router.us.thethings.network (13.66.213.36) port 1700...
    [ 983.289] Setting up the LoRa radio at 903.9001 Mhz using SF10BW125
    [ 983.299] LoRaWAN nano gateway online
    [ 983.304] You may now press ENTER to enter the REPL
    Please help.
    EDIT:
    • I deleted the gateway from the registry
    • changed how the gateway ID is comprised by using this (as it was originally instead of my own ID):
    GATEWAY_ID = WIFI_MAC[:6] + "FFFE" + WIFI_MAC[6:12]
    • Then I registered the gateway with this ID.
      This fixed the problem of missing push/pull acks....
    However, the gateway is still showing in TTN Console as "not connected".
    Anybody can explain to me why? And how to fix that?
    EDIT2:
    Then after I started it with Upload and after 28 pairs of push/pull ack, I got this (a single packet from hell ;-):
    5266.078] Push ack
    [ 5281.065] Pull ack
    [ 5306.062] Pull ack
    [ 5326.067] Push ack
    [ 5331.073] Pull ack
    [ 5356.067] Pull ack
    [ 5381.071] Pull ack
    [ 5386.056] Push ack
    [ 5406.065] Pull ack
    [ 5406.543] Received packet: {"rxpk": [{"data": "oP0suSa13tED8G+NfAz5yHUMH7Yk7ayZQUVWVCyFVle2OCWcfa6RyoxCDoNuQ+DpcOVVQXQLImCv+eQo4L1YGvN+oTFX/XimQmjAMXoVCPf+G0AoA7Z2eA==", "time": "2019-08-26T22:56:39.303916Z", "chan": 0, "tmst": 1107406754, "stat": 1, "modu": "LORA", "lsnr": -13.0, "rssi": -123, "rfch": 0, "codr": "4/5", "freq": 903.9, "datr": "SF7BW125", "size": 88}]}
    [ 5406.610] Push ack
    [ 5431.056] Pull ack
    [ 5446.067] Push ack
    [ 5456.073] Pull ack
    No Idea, how and why...Could it be because I switched from SF10BW125 to SF7BW125 ?
    EDIT3:
    So the LoRa code is there and the questions remain against it since something is not working there and there is no way to know what...Considering this and how long it took to install DFU drivers and firmware updates for LoPy and Expansition Boards with this Zadig clumsiness, I am asking myself whether is it the right move to consider LoRaWAN at all...
  • @securigy The single packet you have seen may be just noise. We see these all the time. The CRC should be wrong.
