Flash memory life with regular write into file
Hi, i have such an quite big project build on pycom and i would like to know the life time of flash memory life in case of regular writing into file.
What i mean is that i use logging and in one cycle log is called 5-15 times. Say that 8 logs is written most of the time, flash should be available of 100,000 writing at least.
In my humble calculations it seems like this:
- 100,000 writings / 8 logs-per-cycle ~= 12,500 cycles
- 12,500 cycles / 10 cycles-per-day ~= 3 years and 5 months of life time at least
but..., there is also uploads of code onto flash and another file writings i use and so on...
So my questions to the discussion are that I would like to know if:
- are my approximations right?
- what does 10 "small" entries vs. one "large" entry? Is it just about writing or also about the amount of data that we want to write into flash memory?
Thanks.
With FATFS the life time of the internal flash is smaller than with LittleFS (on development firmware version).
But how much increase in life time with LittleFS ? I don't know.
