    rtc.ntp_sync restart after 30 seconds?
    6 Posts 2 Posters 531 Views 2 Watching
    • W Offline
      Wolli01
      How can it be done, that no internet connection to the time server will cause a restart after 30 seconds?
      This is my current code.
      rtc.ntp_sync("de.pool.ntp.org")
      while not rtc.synced():
      utime.timezone(TimeDiff)
      time1 = utime.localtime() # Übergabe Datum und
      break
        robert-hh @Wolli01
        @Wolli01 So I understand that you code is:
        break
        So why the break at the. Is there another while loop which you do not show?
        W 1 Reply Last reply Reply Quote 0
        • W Offline
          Wolli01 @robert-hh
          @robert-hh No there are no more loops
            robert-hh @Wolli01
            @Wolli01 SO I extended your code snippet to a short test script:
            import utime
            rtc=machine.RTC()
            TimeDiff = 0
            print(time1)
            That works, does not restart after 30 seconds, but waits forever, if not WiFi is present. I disabled WIFi by calling disconnect().
            Pycom MicroPython 1.20.0.rc13 [1211d6c-dirty] on 2019-08-23; FiPy with ESP32
            • W Offline
              Wolli01 @robert-hh
              @robert-hh Apart from the last line, what's the difference?
                robert-hh @Wolli01
                @Wolli01 The break in your code should simply cause an error while parsing:
                SyntaxError: 'break' outside loop
