    Lopy to Lopy example is not working...or incomplete by design?
    5 Posts 3 Posters 285 Views 3 Watching
    • securigyS Offline
      securigy
      So after having PySense + LoPy4 connected to TTN via real gateway (TTIG) I decided to try making PySense+LopY4 to talk to PyTrack+LoPy4. I looked at the example code LoPy to Lopy and it looked that there is nothing easier than that...
      I do all this with VS Code + PyMakr and connecting to each node from different laptop via corresponding COM ports...
      In VS Code I opened a folder on each laptop for LoPy A and LoPy B and changed the frequency and added the correct region for the U.S.:
      lora = LoRa(mode=LoRa.LORA, frequency=903900000, region=LoRa.US915)
      I ran the code on each laptop - but nothing happens...should I add a single channel? If yes, why the examples come without it? Anything else I am missing?
        Gruger
        There is no print in the example code - so no obvious check if Node A is receiving any data. Add a print('Pong') below s.send('Pong').
        securigyS 1 Reply Last reply Reply Quote 0
        • securigyS Offline
          securigy @Gruger
          @Gruger I realize that there are no "print" statements. My point/question was whether anybody knows if this sample works at all - may be with some changes that were not mentioned?
          • securigyS Offline
            securigy @securigy
            @securigy Never mind. With a little bit of digging it works. Example explanations and comments? What for?..
              robert-hh @securigy
              @securigy Sometimes They work, sometimes not. my experience with Lora: Always start tests from a fresh power-up.
