Warning To All Visual Studio Code / Pymakr Extension Users
If you use the Pymakr extension to upload files, be aware of the following problem.
import os
os.remove('any_source_file.py')Click the "Upload Project" button at bottom of screen.
The upload will not detect that the source file has been deleted! The sync does not work in this case.
Another issue with Pymakr was discovered yesterday. If you install Visual Studio Code on a newly installed Windows 10 and add the Pymakr extension, it will not communicate with the GPy until Node is also installed on the computer.
