connecting Lopy 4 with raspberry pi over wifi
Hi everyone
I am trying to send some data from raspberry pi to Lopy 4 through wifi. I would appreciate your guidance, if any you have done this before.
Thank you in advance.
@tam Step 1: make a wifi connection. Either connect both devices to the same Access Point (AP), or configure one of the as AP (for the LoPy, this is easy), and the other as station.
Step 2: Use a standard socket connection. May examples can be found on the net, for instance here: https://docs.pycom.io/tutorials/all/socket/
or here: https://pymotw.com/3/socket/tcp.html
or here: https://docs.python.org/3/howto/sockets.html (Normative) -
@robert-hh sorry for the late response and thank you for your reply. I will try and let you know the progress.
Regards
Tam -
@robert-hh Thank you for your advice. I could send and receive some data from raspberry pi to lopy4. Now I am trying to send an ASCII txt file (1 KB) from raspberry pi to lopy 4 but I couldn't send the image.
I would appreciate your guidance, if you help me out.
regards
Tam
