Servo Motor Issues
I'm new to pycom and using the GPy board. I have my board attached to an expansion board v3.1 and I am trying to control a servo motor by starting it at on location and then setting it at another location.
I'm using the example code given @ the PWM documentation page and configured it to my the way my pins are setup, yet when I run my program on my device the servo motor just spins uncontrollably.
Can someone help explain to me why this is happening, my code is as follows:
from machine import PWM pwm = PWM(0, frequency=5000) # use PWM timer 0, with a frequency of 5KHz pwm_c = pwm.channel(0, pin='P22', duty_cycle=0.5) pwm_c.duty_cycle(0.3)
I solved my own problem, I realized the frequency was too high and that the duty cycle should be between 5 and 10 percent.
I used Sparkfun's PWM page to help me get this information and solve my issue. The link is here:
https://learn.sparkfun.com/tutorials/pulse-width-modulation/allAlso my code is here for anyone who may run into the same issue with a servo motor:
from machine import PWM from time import sleep pwm = PWM(0,frequency=50) # use PWM timer 0, with a frequency of 50Hz pwm_c = pwm.channel(0,pin='P8', duty_cycle=1) while True: pwm_c.duty_cycle(0.097) sleep(1) pwm_c.duty_cycle(0.043) sleep(1) pwm_c.duty_cycle(0.097)
