    BLE scan between pycoms
    2 Posts 2 Posters 302 Views 2 Watching
    • M Offline
      mdelhorno
      Hi everyone,
      I’m trying to develop an application that continuously scan the BLE network and gets the RSSI level from some devices I selected.
      My testbed is composed by:
      • 5 WiPy3 + pysense board. Firmware: 1.18.2.r7
      • 1 WiPy3 + pysense board: Firmware: 1.17.5.b6
      • 1 WiPy3 + pytrack board. Firmware: 1.18.0
      All of them are running the same code (below) but the only board that gets BLE measurements of the other devices is the pytrack (pysenses don’t “see” each other). This is the first time that I use BLE so I might have a lack of understanding about how BLE works.
      bt = Bluetooth()
      bt.set_advertisement(name=client_id, service_uuid=b'1234567890123456')
      bt.advertise(True)
      macs_bt = {‘MAC-1’, ‘MAC-2’, ‘MAC-3’, ‘MAC-4’, ‘MAC-5’, ‘MAC-6’, ‘MAC-7’}
      rssi_bt = []
      def scan_bluetooth(delay):
          bt.start_scan(-1)
              try:
                  rssi = {}
                  advs = bt.get_advertisements()
                  for ad in advs:
                      bssid = change_mac_format(ubinascii.hexlify(ad.mac).decode('utf-8'))
                      if bssid in macs_bt:
                          rssi[bssid] = ad.rssi
                  if rssi:
                      rssi['timestamp'] = get_date()
                      rssi_bt.append(rssi)
                  time.sleep(delay)
              except Exception as ex:
                  sys.print_exception(ex)
      Any idea what’s going on?
      O 1 Reply Last reply Reply Quote 0
      • O Offline
        oligauc @mdelhorno
        @mdelhorno Please can you send you full code to support@pycom.io . The code below is working for me:
        from network import Bluetooth
        import utime
        bluetooth = Bluetooth()
        bluetooth.set_advertisement(name='Module_1', service_uuid=b'1234567890123456')
        bluetooth.advertise(True)
        bluetooth.start_scan(-1)    # start scanning with no timeout
            print(bluetooth.get_adv())
            utime.sleep(0.2)
