    Improved Initialize LTE
    2 Posts 2 Posters 390 Views 2 Watching
      tlanier
      The LTE() constructor causes the modem to reboot when the call occurs after a power up. The reboot does not occur if you reset the chip. This can lead to hard to find bugs in the communication routines. I've added a wait_response('+SHUTDOWN', 4000) call to detect the modem restart and then a call to wait_response('+SYSSTART', 15000) which indicates the modem is ready.
      In the lte.isattached() method, Pycom uses the AT+CFUN? command to test if radios have been turned off. If the radios are off, this indicates the modem has crashed and they try to fix with the AT+CFUN=1 command. The problem with this is all the modem setup has been lost at that point (band setup, user configured modem settings, ...). When we initialize the modem we set the SMS text mode using the at('AT+CMGF=1') command. Since the setting is reset to 0 if the modem restarts, we can use the test AT+CMGF? != 1 to detect any modem crashes so we can do a modem reset and reinitialization.
      I think a better option would be for Pycom to set a python testable flag if the modem crashes.
      lte = None
      #                     Send AT Command To Modem
      def at(cmd):
          try:
              log("modem command: {}".format(cmd))
              util.wait()
              # lte.send_at_cmd(cmd, delay=10000)
              r = lte.send_at_cmd(cmd).split('\r\n')
              task_switch()
              r = list(filter(None, r))
              log("response: {}".format(r))
              task_switch()
          except Exception as ex:
              sys.print_exception(ex)
              r = []
          return r
      #                         Initialize LTE
      def init_lte():
          global lte
          try:
              log('initializing LTE...')
              task_switch()
              lte = LTE()
              task_switch()
              # modem will restart on power up situations
              r = wait_response('+SHUTDOWN', 4000)
              if r == True:
              util.reset(27, "LTE exception")
      #                         Initialize Modem
      def init_modem():
          try:
              if lte == None:
                  init_lte()
              g.modem_state = g.MS_INIT_MODEM
              log("initializing modem...")
              log("set SMS mode to text")
              at('AT+CMGF=1')     # set SMS mode to text
              # if AT+CMFG? returns 0, the modem has crashed/restarted
              task_switch()
              lte.init()
              # lte.init(carrier='att')   # no known advantage
              task_switch()
              g.oIni.apn = g.oIni.apn_89014
              log("Kore AT&T SIM - APN: {0}".format(g.oIni.apn))
      #               Is Cellular Modem Attached To Base Station
      def isattached():
          # returns: True/False
          try:
              task_switch()
              r = lte.isattached()
              # Pycom uses AT+CFUN? to test if radios have been turned off
              # this indicates modem has crashed and they try to fix with AT+CFUN=1
              # the problem is all the modem setup has been lost at that point
              # we will test AT+CMGF? != 1 to detect crash and then restart
              task_switch()
              if r == True:
                  g.modem_state = g.MS_REGISTERED
              r = False
          return r
      #                  Modem Restarted/Crashed Check
      def restarted():
          # return True if modem has crashed / restarted
          # if SMS text mode is reset to zero, modem has crashed / restarted
          try:
              r = at('AT+CMGF?')
              # response: ['+CMGF: 1', 'OK']
              if len(r) == 0:
                  return False     # state unknown
              s = r[0]
              if (s[0:6] != '+CMGF:'):
              mode = int(s[7])
              if mode != 1:
                  return True    # modem has crashed /restarted
              return False
      #                    Wait For Specific Modem Response
      def wait_response(response, msecs=10000):
          log('wait up to {0} msecs for modem response: {1}'.format(msecs, response))
          t0 = ticks_ms()
              try:
                  t1 = ticks_ms()
                  tx = ticks_diff(t1, t0)
                  log('{0} msecs'.format(tx))
                  r = at('AT')
                  t1 = ticks_ms()
                  for x in r:
                      if x == response:
                          log('****modem response found****: ' + response)
                          return True
                  if tx > msecs:
                      log('modem response not found: ' + response)
                      return False
                  sleep_ms(1000)
      • K Offline
        kjm
        You can check for modem crashes with
        mood=lte.send_at_cmd('at+cpin?').split('\r\n')[1]; print('mood =', mood)
        anything other than READY or +SYSSTART means the modem is crashed.
