    getaddrinfo in a thread
    threadgettaddrinfo
    7 Posts 3 Posters 1.0k Views 4 Watching
    • K Offline
      kjm
      DNS lookups via 4G on a GPY can take up to 20s if things don't go well
      import time, usocket, _thread
      def _dns(host, port):
        ai = usocket.getaddrinfo(host, port); ai=ai[0]; return ai
      start=time.time()
      ai=_dns('some url', 443)
      stop=time.time(); wait=stop-start; print('wait =', wait, ' dns =', ai)
      for example, returns
      wait = 14  dns = (2, 1, 0, '', ('0.0.0.0', 443))
      Since we can't wait that long in a battery powered GPY we tried a thread
        global ai; ai=usocket.getaddrinfo(host, port); ai=ai[0]
      start=time.time(); ai=0
      _thread.start_new_thread(_dns, ('some url', 443))
      for i in range(5):
        print(i, ai), time.sleep(1)
        if ai: break
      more or less the same result
      0 0
      wait = 13  dns = (2, 1, 0, '', ('0.0.0.0', 443))
      We don't get it. Why doesn't the main program timeout after 5s? Why does it pause after the first iteration of the loop & wait for the thread? Isn't the idea of a thread that it allows the main program to continue regardless of what the thread is doing?
      O 1 Reply Last reply Reply Quote 0
      • O Offline
        oligauc @kjm
        @kjm GPY works with the 5G LTE CAT M1 and NB-Iot. You need to buy a 5G sim card from a service provider and follow the examples found on our website: CAT M1 and NB-Iot
        • K Offline
          kjm
          Is this guy for real?!
          • K Offline
            kjm @oligauc
              andreas
              getaddrinfo does not only have issues on MicroPython when used in a thread [1]. These things are tricky.
              [1] https://emptysqua.re/blog/getaddrinfo-deadlock/
                andreas
                What should print(i, ai), time.sleep(1) actually do? I believe your thread might crash without notice.
                @andreas said in urequests timeouts:
                I can't decipher your code
                However, you might want to add machine.idle() while you are waiting for the thread outcome in order to feed the OS scheduler.
                  andreas
                  Just retyped this for the sake of improved readability. You might want to save it as /flash/lib/dnstest.py.
                  import usocket
                  import _thread
                  >>> import dnstest; dnstest.dns_lookup('google.com')
                  0 None
                  1 (2, 1, 0, '', ('172.217.18.14', 443))
                  2 (2, 1, 0, '', ('172.217.18.14', 443))
                  3 (2, 1, 0, '', ('172.217.18.14', 443))
                  4 (2, 1, 0, '', ('172.217.18.14', 443))
                  response = None
                  def run_getaddrinfo(host, port):
                      global response
                      response = usocket.getaddrinfo(host, port)[0]
                  def dns_lookup(hostname, timeout=5):
                      _thread.start_new_thread(run_getaddrinfo, (hostname, 443))
                      for i in range(timeout):
                          print(i, response)
                          machine.idle()
                      print('Ready.')
                  It works flawlessly over a WiFi connection, but LTE might well have its delicacies.
