    Syncing the clocks of Lora/Pymeshed Devices
    3 Posts 2 Posters 338 Views 3 Watching
    • B Offline
      boda
      I am building a testing series of meshed devices that are listening for Bluetooth Beacon advertisements. But I need to sync the clock of the nodes to get accurate measurements. Is there any way I can do something like this using PyCom's libraries? Thanks!
      For reference, "PainlessMesh" is a wifi-meshing library that syncs the node(s) clocks: https://gitlab.com/painlessMesh/painlessMesh/blob/master/examples/startHere/startHere.ino
      O 1 Reply Last reply Reply Quote 0
      • O Offline
        oligauc @boda
        @boda Please find example code below on how the sync clock.
        from machine import RTC
        from network import WLAN
        wlan = WLAN(mode=WLAN.STA)
        wlan.connect('your ssid', auth=(None, 'your pass'))
        while not wlan.isconnected():
            machine.idle()
        print('WiFi connected')
        rtc = machine.RTC()
        rtc.ntp_sync('pool.ntp.org', update_period=3600)
        while not rtc.synced():
            machine.idle()
        print("RTC NTP sync complete")
        print(rtc.now())
        • B Offline
          boda @oligauc
          @oligauc Thank you!
