microWebSrv2
Hello all,
I released a fully new version (v2.0) of my web server here : https://github.com/jczic/MicroWebSrv2.
Open source MIT, fully asynchronous, more robust, more fast and more efficient on Pycom modules.
It is delivered with a good documentation.
Thank you for your support and feedback. ☺️
@pigamonte I took two wipy's and let them run over night. Both in station mode connected to same wifi as the laptop. both running microWebSrv2 example and Firefox browser on my laptop requesting the websites repeatedly using a browser extension (Tab Reloader) to refresh every 5 seconds. Neither Wipy core dumped. They served 3000+ GET's each until approx 21:15, which means probably 2h or so of runtime until both of them stopped with an uncaught micropython exception. Probably running out of memory
Unhandled exception in thread started by <bound_method> Traceback (most recent call last): File "MicroWebSrv2/libs/XAsyncSockets.py", line 141, in _processWaitEvents File "MicroWebSrv2/libs/XAsyncSockets.py", line 125, in _processWaitEvents File "MicroWebSrv2/libs/XAsyncSockets.py", line 88, in _socketListAdd MemoryError: memory allocation failed, allocating 16384 bytes
- How exactly are you erasing/flashing? With the Firmware Updater application https://docs.pycom.io/updatefirmware/device/ ? Makefile? Self compiled? Please elaborate
- Please show the ...on_boot settings as per my last post
- How do you supply power to the Wipy? USB from laptop? Anything else connected?
- Do you have multiple Wipy's and Expansion boards to try? How many? Is the behaviour different?
- Is it a Wipy2 or Wipy3 (printed on the bottom)
- Can you try other usb ports/ cables/ power supplies?
@peterp, Thanks for testing. I set my test up again to see how you got yours to work for 230+ gets. It appears the problem isn't linked to MicroWebSrv2 at all.
I erased the wipy and reloaded fw 1.20.2.r4. Then, without loading any code or making any configuration, I connect to the default access point. Within a minute or two the wipy crashes. My PC must be sending some traffic that causes the crash.
Here are more dumps as requested by @Gijs
Guru Meditation Error: Core 0 panic'ed (IllegalInstruction). Exception was unhandled. Memory dump at 0x4017b314: 00000099 03064000 80145070 Core 0 register dump: PC : 0x4017b319 PS : 0x00060a30 A0 : 0x8017f804 A1 : 0x3ffbaee0 A2 : 0x3fbc1674 A3 : 0x3ffdfa8c A4 : 0x00000004 A5 : 0xffffffff A6 : 0x3fbc1622 A7 : 0x00000045 A8 : 0x80175d83 A9 : 0x3ffbaed0 A10 : 0x00000000 A11 : 0x0001003c A12 : 0x00000000 A13 : 0x00000000 A14 : 0x3ffb9f88 A15 : 0x00000001 SAR : 0x00000019 EXCCAUSE: 0x00000000 EXCVADDR: 0x00000000 LBEG : 0x40092834 LEND : 0x40092862 LCOUNT : 0xffffffff ELF file SHA256: 0000000000000000000000000000000000000000000000000000000000000000 Backtrace: 0x4017b319:0x3ffbaee0 0x4017f801:0x3ffbaf10 0x4016fe1d:0x3ffbaf30
Guru Meditation Error: Core 0 panic'ed (LoadProhibited). Exception was unhandled. Core 0 register dump: PC : 0x4011fd46 PS : 0x00060c30 A0 : 0x00000011 A1 : 0x3ffb41c0 A2 : 0x3fbc195c A3 : 0x00000000 A4 : 0x00000001 A5 : 0x00000001 A6 : 0x00000000 A7 : 0x00000008 A8 : 0x00124040 A9 : 0x3ffb41c0 A10 : 0x3ffb420e A11 : 0x3ffe28f4 A12 : 0x00000004 A13 : 0x3ffb4214 A14 : 0x777749d2 A15 : 0x777749d2 SAR : 0x00000010 EXCCAUSE: 0x0000001c EXCVADDR: 0x00000026 LBEG : 0x40092834 LEND : 0x40092862 LCOUNT : 0xffffffff ELF file SHA256: 0000000000000000000000000000000000000000000000000000000000000000 Backtrace: 0x4011fd46:0x3ffb41c0 0x0000000e:0x3ffb41f0 0x4014b02d:0x3ffb4290
Guru Meditation Error: Core 0 panic'ed (InstrFetchProhibited). Exception was unhandled. Core 0 register dump: PC : 0xc1250358 PS : 0x00060c30 A0 : 0xc1250358 A1 : 0x3ffb4210 A2 : 0x00000001 A3 : 0x00000000 A4 : 0x3ffb4518 A5 : 0x3ffcc558 A6 : 0x77a00000 A7 : 0x3ffb4518 A8 : 0x40087d1c A9 : 0x0003ff00 A10 : 0x00000000 A11 : 0x00000000 A12 : 0x00000000 A13 : 0x3ffc0d4c A14 : 0x000000fe A15 : 0x00000001 SAR : 0x0000001c EXCCAUSE: 0x00000014 EXCVADDR: 0xc1250358 LBEG : 0x40092834 LEND : 0x40092862 LCOUNT : 0xffffffff ELF file SHA256: 0000000000000000000000000000000000000000000000000000000000000000 Backtrace: 0x41250358:0x3ffb4210 0x41250355:0x3ffb4290
Guru Meditation Error: Core 0 panic'ed (LoadProhibited). Exception was unhandled. Core 0 register dump: PC : 0x4014ff7b PS : 0x00060e30 A0 : 0x8014b079 A1 : 0x3ffb4210 A2 : 0x00000079 A3 : 0x00000018 A4 : 0x3ffb450c A5 : 0x3ffcc558 A6 : 0x3fbc1e74 A7 : 0x3ffb4588 A8 : 0x8014ff60 A9 : 0x3fbc1ea4 A10 : 0x3fbc1e74 A11 : 0x3ffc0e38 A12 : 0x3ffc0460 A13 : 0x0000001c A14 : 0x00000001 A15 : 0x0000009d SAR : 0x00000019 EXCCAUSE: 0x0000001c EXCVADDR: 0x8014b079 LBEG : 0x400919b4 LEND : 0x400919bf LCOUNT : 0x00000000 ELF file SHA256: 0000000000000000000000000000000000000000000000000000000000000000 Backtrace: 0x4014ff7b:0x3ffb4210 0x4014b076:0x3ffb4290
@pigamonte Ok, I let this run for a while (230 GET's). No problem so far. How quickly do you get a crash? How stable is the reproduction? Does it happen regularly, or is it very random? Do you think that Access Point is critical for the reproduction? Or can you also reproduce the problem with Station mode? It would be easier for me to let it run a long time if I could use station mode.
Edit: Also, which FW are you using? And please post the output of
import pycom print('heartbeat', pycom.heartbeat_on_boot()) print('lte', pycom.lte_modem_en_on_boot()) print('pybytes', pycom.pybytes_on_boot()) print('smart_config', pycom.smart_config_on_boot()) print('wdt', pycom.wdt_on_boot()) print('wifi', pycom.wifi_on_boot())
Did you notice any difference between WiPy's if you have multiple? Some crash (more often) than others?
@pigamonte
I am little surprised that it run now without frozen modules :)
Previous versions require to froze code to optimize memory usage
@peterp Please download from here . I changed one line in the index.html inside the head tag in order to reproduce easily.
<meta http-equiv="Refresh" content="4; url=/index.html" />
The head tag will look like this
<head> <meta charset="UTF-8" /> <title>MicroWebSrv2</title> <link rel="stylesheet" href="style.css" /> <meta http-equiv="Refresh" content="4; url=/index.html" /> </head>
The hardware setup is just the wipy on the pycom Expansion board powered via USB.
To see it fail, connect your device to the default access point on the wipy, then open a browser at 192.168.4.1 and wait a few moments.
I have decoded the backtraces using the Pybytes firmware version of the Wipy (1.20.2.r4), in order, we get:
wdevProcessRxSucDataAll ??:? ppTask ??:?
pbuf_header_impl /home/peter/docs/pycom-esp-idf/components/lwip/lwip/src/core/pbuf.c:1331 pbuf_header /home/peter/docs/pycom-esp-idf/components/lwip/lwip/src/core/pbuf.c:1331 ethernet_input /home/peter/docs/pycom-esp-idf/components/lwip/lwip/src/netif/ethernet.c:176 tcpip_thread /home/peter/docs/pycom-esp-idf/components/lwip/lwip/src/api/tcpip.c:483
and
ieee80211_crypto_decap ??:? ieee80211_crypto_encap ??:? ieee80211_output_process ??:? ppTask ??:?
There seems to be no commonality between the three unfortunately, and two of them are related to the esp-idf part, which is outside the pycom firmware. Do you perhaps have any more that we could look at?
Note that coredumps could also be related to transients on the power supply and memory allocation. I dont know anything about the size of your program, but if we're reaching the memory limit, the
StoreProhibited
error could be related to that.
@pigamonte could you share your python code?
@Gijs The dumps are different every time. Here are 3 for example.
Core 0 register dump:: Core 0 panic'ed (LoadProhibited). Exception was unhandled. PC : 0x4014ff7b PS : 0x00060e30 A0 : 0x8014b079 A1 : 0x3ffb4210 A2 : 0xb6000000 A3 : 0x00000018 A4 : 0x3ffb4548 A5 : 0x3ffcc558 A6 : 0xbfbcff6c A7 : 0x3ffde18c A8 : 0x8014ff60 A9 : 0x3ffb41d0 A10 : 0x3fbc2b6c A11 : 0x3ffc0e38 A12 : 0x3ffc0460 A13 : 0x00000000 A14 : 0x00000001 A15 : 0x0000019c SAR : 0x00000010 EXCCAUSE: 0x0000001c EXCVADDR: 0x8014b079 LBEG : 0x400919b4 LEND : 0x400919bf LCOUNT : 0x00000000 ELF file SHA256: 0000000000000000000000000000000000000000000000000000000000000000 Backtrace: 0x4014ff7b:0x3ffb4210 0x4014b076:0x3ffb4290
Guru Meditation Error: Core 0 panic'ed (IllegalInstruction). Exception was unhandled. Memory dump at 0x40175d1c: 2af6f4a0 0083d41c 070518a2 Core 0 register dump: PC : 0x40175d21 PS : 0x00060e30 A0 : 0x80175d83 A1 : 0x3ffbaed0 A2 : 0x0000000e A3 : 0xfffffff2 A4 : 0x00000000 A5 : 0x00000000 A6 : 0x3ffb9f74 A7 : 0x00000001 A8 : 0x3fbc24fc A9 : 0x3fbc13bc A10 : 0x00000001 A11 : 0x00000000 A12 : 0xffffffff A13 : 0x00000001 A14 : 0x000000fe A15 : 0x00000000 SAR : 0x00000019 EXCCAUSE: 0x00000000 EXCVADDR: 0x00000000 LBEG : 0x40092834 LEND : 0x40092862 LCOUNT : 0xffffffff ELF file SHA256: 0000000000000000000000000000000000000000000000000000000000000000 Backtrace: 0x40175d21:0x3ffbaed0 0x40175d80:0x3ffbaef0 0x4017f7f8:0x3ffbaf10 0x4016fe1d:0x3ffbaf30
Guru Meditation Error: Core 0 panic'ed (StoreProhibited). Exception was unhandled. Core 0 register dump: PC : 0x4011fe4c PS : 0x00060a30 A0 : 0x8011fd80 A1 : 0x3ffb41a0 A2 : 0x3fbc1ea8 A3 : 0x3ffe2cd4 A4 : 0x00000000 A5 : 0x3ffb4214 A6 : 0x777749d2 A7 : 0x777749d2 A8 : 0x3ffe2d4e A9 : 0x3fbc1ea8 A10 : 0x0000003c A11 : 0x000007c6 A12 : 0x00000001 A13 : 0x000007c5 A14 : 0x3ffe2d04 A15 : 0x00000000 SAR : 0x00000010 EXCCAUSE: 0x0000001d EXCVADDR: 0x00000005 LBEG : 0x40092834 LEND : 0x40092862 LCOUNT : 0xffffffff ELF file SHA256: 0000000000000000000000000000000000000000000000000000000000000000 Backtrace: 0x4011fe4c:0x3ffb41a0 0x4011fd7d:0x3ffb41c0 0x4012c876:0x3ffb41f0 0x4014b02d:0x3ffb4290
@pigamonte Perhaps you could take the problem up with them, or check their Github issues for similar problems. Seeing as this topic is over a year old, you might not get a response from them.
If you believe the issue is related to the pycom firmware, could you have a look at this page (https://docs.pycom.io/advance/coredump/) and see if you can decode the coredumps. Let me know what you get, and if it is the same everytime
Best,
MicroWebSrv2 its not running well on wipy. After refreshing the home page a few times wipy will crash with guru meditation error. I tried it with v1.20.2.r4.
