How to save or write files to Lopy flash
  • I am sending an ASCII file from one Lopy4 to another Lopy4 through LoRa and I could send the ASCII characters in packets from one to another where the receiver Lopy receives the packets (I confirmed this as I can print the received packets). Meanwhile I am also trying to save/write the received ASCII packets in the flash memory under "image.txt" of the receiving Lopy4. I used code below but when I download the "image.txt" and view it, it still appears as an empty file.
    from network import LoRa
    lora = LoRa(mode=LoRa.LORA, frequency=915000000)
    s.setblocking(True)
        # send some data
        rec = s.recv(1024)
        print(rec)
        fo = open("image.txt", "wb")
        fo.write(rec)
    I may be doing wrong. If any one can help me on how to write/save the received packets to "image.txt" file that I created.
    Your kind help will be appreciated
    Thank you
  • @rcolistete If using the nvs class by @oligauc below: that one indeed writes to the flash file system. If you use the nvs_xxxx methods from the pycom module, data is stored in the separate nvs partition and not in the file system partition.
  • @robert-hh But isn't '/flash/store.nvram' a common file in '/flash' file system ?
  • @gcapilot No, it does not. It write to a special area of the flash, but not the file system in flash, which is located in the so called nvs partition at offset 0x9000, size 0x7000.
  • @oligauc said in How to save or write files to Lopy flash:
    from nvs import Nvs
    nvs_obj = Nvs(',', 512)
    nvs_obj.store('test write 1')
    nvs_obj.store('writing the second line to nvs')
    nvs_obj.store('this is the third line')
    buf = nvs_obj.read_all()
    print('Data read from file: {}'.format(buf))
    Doesn't this code just create a regular file and write/read to it?
  • Other example, using 'with' there is no need do close the file (it is done in the end of the 'with' block :
            try:
                with open('/flash/log.txt', 'a') as f:
                    f.write('test')
                os.sync()
            except OSError as e:
                print('Error {} writing to file'.format(e))
  • @phusy012
    You have to close the file. If you don't close or flush the stream, the payload may remain in the buffer and will not be written on your device. Because there is no working flush, you have to close the file.
  • @oligauc Thank you so much. I shall try and seek your help if I get stuck. Thank you once again.
  • @phusy012 Please find example code below.
    Create a file named nvs.py
    import uos
    class Nvs:
        def __init__(self, delimiter, file_size):
            self.max_file_size = file_size
            self.delimiter = delimiter
            self.file_path = '/flash/store.nvram'
            self.file_handle = None
        def empty(self):
            isEmpty = False
            try:
                if uos.stat(self.file_path)[6] == 0:
                    isEmpty = True
            except Exception as e:
                isEmpty = True
            return isEmpty
        def full(self):
            isFull = True
            try:
                if uos.stat(self.file_path)[6] < self.max_file_size:
                    isFull = False
                isFull = False
            return isFull
        def open(self):
            if self.file_handle is None:
                self.file_handle = open(self.file_path, "a+")
        def close(self):
            if self.file_handle:
                self.file_handle.close()
        def store(self, data):
            if self.full():
                return False
                self.open()
            try:
                self.file_handle.write(data)
                self.file_handle.write(self.delimiter)
                self.file_handle.flush()
                print("NVRAM: Exception storing data: " + str(e))
                return False
            return True
        def read_all(self):
            buf = ''
                self.open()
            try:
                self.file_handle.seek(0,0)
                buf = self.file_handle.read()
                print("NVRAM: Exception reading file: " + str(e))
            return buf
    Create a file named main.py
    from nvs import Nvs
