    Failed to connect (Error: Port is not open)
    4 Posts 3 Posters 454 Views 3 Watching
    • N Offline
      Nebr
      Re: Stuck at "Failed to connect (Error: Port is not open)" between Atom and GPy/Pysense on Fedora computer
      I have the same problem as the referenced thread.
      Ubuntu 18.04.3 LTS
      Atom v1.38.2
      pymakr v1.4.14
      I also can get the above combination of Atom and pymakr versions to work on a Windows machine, but I need to get it working in Linux.
      Any help would be appreciated.
      N O robert-hhR 3 Replies Last reply Reply Quote 0
      • N Offline
        Nebr @Nebr
        @Nebr Update:
        Every thing seems to be working at this point.
        Under the pymakr Settings>Global settings if you page down to the bottom there is a "Cannot connect to Pycom device on Linux" section (shame on me for not finding this sooner). Running the command sudo usermod -a -G dialout $USER as directed seems to have solved the issue.
        • O Offline
          oligauc @Nebr
          @Nebr That is a permission issues on your port. To verify you can try sudo chmod 777 /dev/ttyACM0 and then try to connect
            robert-hh @Nebr
            @Nebr You could try to add yourself to the dialout group:
            sudo adduser <your name> dialout
            And then logout/login, or to be safe, reboot.
