SHT21D I2C and WIPY2
  • I have the SHT21(D) temperature / humidity sensor hooked up to the WIPY2 with 10K pullups on SDA and SCL, however it cannot be discovered.
    I am sure that the device is not fried and was new from element 14 last Friday.
    If I connect another I2C device (24C01 Eeprom) then it returns the device correctly, however the SHT21 refuses to cooperate.
    I know you don't have much to go on, but any suggestions on how to debug or what the cause may be ??
      from machine import I2C
      i2c = I2C(0, I2C.MASTER, baudrate=100000)
      print(i2c.scan())
  • @affoltep
    How do I get normal decimal values?
  • @affoltep Thanks, I am using the three properties from measure separately. (self.temperature, self.humidity, self.dewPoint)
    I do a string conversion and send them as JSON. So before converting to a string, I have these float values?
    Should I convert these into a byte array to convert it into a network byte order? I am about to read these values back in C#.
  • @lollisoft if you are asking about sht1x then you find two methods to read raw temperature and raw humidity values in the class which are binaries. If you talk about SHT 2x, then you can read raw values over the i2c interface.
    Hope this is the fitting response to your question.
  • @affoltep Is there any way to encode the values in a compact binary format?
  • @affoltep thank you very much
    you read my thought about the driver ! I was wondering how can I get it for the pycom!
  • @maamar I use the standard pins P9 for SDA and P10 for SCL. The point with the SHT10 is that it does not support the standard I2C protocol which works for the SHT2x. You need to use a dedicated lib. I ported a SHT15 python library to the syntax of the pycom. Feel free to use it for your application.
    # -*- coding: utf-8 -*-
    """ Sensirion SHT1x & SHT7x family temperature and humidity sensors
    Created by Markus Schatzl, November 28, 2008
    Released into the public domain
    Revised (v1.1) by Carl Jackson, August 4, 2010
    Rewritten (v2.0) by Carl Jackson, December 10, 2010
    Ported to micropython by Frederic Mantegazza, november, 2014
    Ported to pycon hardware by Peter Affolter, December, 2016
    import math
    from machine import Pin
    import utime
    # Clock pulse timing (us)
    # Lengthening these may assist communication over long wires
    PULSE_LONG  = 3
    PULSE_SHORT = 1
    # Status register bit definitions
    SR_LOW_RES  =  0x01  # 12-bit Temp / 8-bit RH (vs. 14 / 12)
    SR_NORELOAD =  0x02  # No reload of calibrarion data
    SR_HEAT_ON  =  0x04  # Built-in heater on
    SR_BATT_LOW =  0x40  # VDD < 2.47V
    # SHT1X command definitions:
    #                          adr  command r/w
    CMD_MEAS_TEMP   = 0x03   # 000  0001    1
    CMD_MEAS_HUMI   = 0x05   # 000  0010    1
    CMD_STAT_REG_W  = 0x06   # 000  0011    0
    CMD_STAT_REG_R  = 0x07   # 000  0011    1
    CMD_SOFT_RESET  = 0x1e   # 000  1111    0
    # Status register writable bits
    SR_MASK = 0x07
    # Temperature & humidity equation constants
    D1  = -40.1          # for deg C @ 5V
    D2h =   0.01         # for deg C, 14-bit precision
    D2l =   0.04         # for deg C, 12-bit precision
    C1  = -2.0468        # for V4 sensors
    C2h =  0.0367        # for V4 sensors, 12-bit precision
    C3h = -1.5955E-6     # for V4 sensors, 12-bit precision
    C2l =  0.5872        # for V4 sensors, 8-bit precision
    C3l = -4.0845E-4     # for V4 sensors, 8-bit precision
    T1  =  0.01          # for V3 and V4 sensors
    T2h =  0.00008       # for V3 and V4 sensors, 12-bit precision
    T2l =  0.00128       # for V3 and V4 sensors, 8-bit precision
    class SHT1XException(Exception):
    class WrongParam(SHT1XException):
    class NoAcknowledge(SHT1XException):
    class Timeout(SHT1XException):
    class InvalidMeasure(SHT1XException):
    class SHT1X:
        """ SHT1X Sensirion management class
        def __init__(self, dataPin, clockPin):
            """ Init object
            @param dataPin: pin for data line
            @type dataPin: str or pyb.Pin.cpu.Name or pyb.Pin.board.Name
            @param clockPin: pin for clock line
            @type clockPin: str or pyb.Pin.cpu.Name or pyb.Pin.board.Name
            All functions exit with clockPin low and dataPin in input mode
            self._pinData = Pin(dataPin, mode=Pin.OUT)
            self._pinClock = Pin(clockPin, mode=Pin.OUT)
            self._rawDataTemp = None
            self._rawDataHumi = None
            self._measureInitiatedAt = 0
            self._measureReady = False
            # Sensor status register default state
            self._statusRegister = 0x00
            self._initSensor()
        @property
        def temperature(self):
            if self._rawDataTemp is None:
                raise InvalidMeasure
            if self._statusRegister & SR_LOW_RES:
                return D1 + D2l * self._rawDataTemp
                return D1 + D2h * self._rawDataTemp
        @property
        def humidity(self):
                humidity = C1 + C2l * self._rawDataHumi + C3l * self._rawDataHumi ** 2
                humidity += (self.temperature - 25.0) * (T1 + T2l * self._rawDataHumi)
                humidity = C1 + C2h * self._rawDataHumi + C3h * self._rawDataHumi ** 2
                humidity += (self.temperature - 25.0) * (T1 + T2h * self._rawDataHumi)
            if humidity > 100.0:
                humidity = 100.0
            elif humidity < 0.1:
                humidity = 0.1
            return humidity
        @property
        def dewPoint(self):
            k = math.log(self.humidity / 100) + (17.62 * self.temperature) / (243.12 + self.temperature)
            return 243.12 * k / (17.62 - k)
        def _initSensor(self):
            """ Put sensor to default state
            # Reset communication link with sensor
            self._resetConnection()
            # Send soft reset command
            self._putByte(CMD_SOFT_RESET)
        def _resetConnection(self):
            """Communication link reset
            # At least 9 SCK cycles with DATA=1, followed by transmission start sequence
            #      ______________________________________________________         ________
            # DATA:                                                      |_______|
            #          _    _    _    _    _    _    _    _    _        ___     ___
            # SCK : __| |__| |__| |__| |__| |__| |__| |__| |__| |______|   |___|   |______
            # Set data register high before turning on
            self._pinData(True)
            # output driver (avoid possible low pulse)
            self._pinData.init(mode=Pin.OUT)
            utime.sleep_us(PULSE_LONG)
            # 9 clock cycles
            for i in range(0, 9):
                self._pinClock(True)
                self._pinClock(False)
            self._startTransmission()
        def _startTransmission(self):
            """Generate SHT1X-specific transmission start sequence
            # This is where SHT15 does not conform to the I2C standard and is
            # the main reason why the AVR TWI hardware support can not be used.
            #       _____         ________
            # DATA:      |_______|
            #           ___     ___
            # SCK : ___|   |___|   |______
            self._pinData(True)
            utime.sleep_us(PULSE_SHORT)
            self._pinData(False)
            self._pinData(True)
            self._pinData.init(mode=Pin.IN, pull=Pin.PULL_UP)
        def _putByte(self, value):
            """ Write byte to sensor and check for acknowledge
            @raise: NoAcknowledge
            # Set data line to output mode
            # Bit mask to transmit MSB first
            mask = 0x80
            for i in range(8, 0, -1):
                self._pinData.value(value & mask)
                # Generate clock pulse
                # Shift mask for next data bit
                mask >>= 1
            # Return data line to input mode
            # Clock #9 for ACK
            # Verify ACK ('0') received from sensor
            if self._pinData.value():
                raise NoAcknowledge("SHT1X didn't acknowledge data")
            # Finish with clock in low state
        def _getByte(self, ack):
            """  Read byte from sensor
            @param ack: send acknowledge if True
            @type ack: bool
            @raise:
            result = 0
                # Shift received bits towards MSB
                result <<= 1
                # Merge next bit into LSB position
                result |= self._pinData.value()
            # Assert ACK ('0') if ack == 1
            self._pinData.value(ack ^ 1)
            # Clock #9 for ACK / NO_ACK
            return result
        def _readSR(self):
            """ Read status register
            self.startTransmission()
            try:
                self._putByte(CMD_STAT_REG_R)
            except SHT1XException:
                return 0xff
            return self._getByte(ack=False)
        def _writeSR(self, value):
            """ Write status register
            # Mask off unwritable bits
            value &= SR_MASK
            # Save local copy
            self._statusRegister = value
            self._putByte(CMD_STAT_REG_W)
            self._putByte(value)
        def _readData(self):
            """ Get measurement result from sensor
            data = self._getByte(ack=True)
            data = (data << 8) | self._getByte(ack=False)
            return data
        def _initiateMeasure(self, cmd):
            """ Initiate measure
            if cmd == "temp":
                cmd = CMD_MEAS_TEMP
            elif cmd == 'humi':
                cmd = CMD_MEAS_HUMI
                raise WrongParam("measure cmd (%s) must be in ('temp',humi')" % cmd)
            self._measureInitiatedAt = utime.ticks_ms()
            self._putByte(cmd)
        def _isMeasureReady(self):
            """ Check if non-blocking measurement has completed
            # Already done?
            if self._measureReady:
                return True
            # Measure ready yet?
                return False
            self._measureReady = True
            return True
        def _waitForMeasureReady(self, timeout=720):
            """ wait for non blocking measure to complete
            raise: TimeoutError
                if self._isMeasureReady():
                    return
                if utime.ticks_diff(utime.ticks_ms(), self._measureInitiatedAt) >= timeout:
                    raise Timeout("timeout while waiting for measure")
        def measure(self):
            """ All-in-one (blocking)
            @return: temperature, humidity, dewpoint
            @rtype: tuple of 3 float
            self._initiateMeasure('temp')
            #self._waitForMeasureReady()  # does not work outside EventLoop, as it is a coroutine!
            utime.sleep_ms(720)
                self._rawDataTemp = self._readData()
                raise InvalidMeasure("measure not ready")
            self._rawDataHumi = self._initiateMeasure('humi')
            utime.sleep_ms(720)
                self._rawDataHumi = self._readData()
            return self.temperature, self.humidity, self.dewPoint
        def getrawtemp(self):
            """ Gets the temperature as raw value (blocking)
            @return: raw temperature
            @rtype: bytes
            utime.sleep_ms(720)
                return self._readData()
        def getrawhumidity(self):
            """ Gets the humidity as raw value (blocking)
            @return: raw humidity
            @rtype: bytes
            utime.sleep_ms(720)
        def reset(self):
            """ Reset function
            Soft reset returns sensor status register to default values
            self._initSensor()
    def main():
        sht1x = SHT1X('P9', 'P10')
        print(sht1x.measure())
    if __name__ == "__main__":
        main()
  • @affoltep could you tell me wich gpio you have used (data and sck)
    I have SHT10
  • @livius & @affoltep - Thanks so much for the suggestions, actually I made a stupid mistake and had the data and clock lines switched, everything worked once I corrected it.
  • Here is an example that is working for the SHT2x. Pullup's are not needed (they are integrated in xiPy)
    i2c.scan() does not detect the sensor.
    import array
    import binascii
    #Init bus
    #SHT20 Temperature command (use no hold master only commands --> 0xF3 )
    command = array.array('B', [0xF3])
    result = array.array('B',  [0, 0, 0])
    print(i2c.writeto(0x40, command))
    time.sleep(0.1)
    result = binascii.hexlify(i2c.readfrom(0x40, 3))
    print(result)
  • @crankshaft
    i can not help because i have not this sensor
    and if you have clear sensor then like this
    alt text
    you must have 100nf between VCC and GND
    0_1485105061043_upload-e04d3286-64b9-4d1a-816a-6943f0dfd1a2
    0_1485105822206_upload-7ea5ff69-e7ee-42eb-9ed1-a6a18818b694
  • @livius - Thanks for the suggestion, but your example uses breakout boards which have the pullups onboard, in my case I am using the device directly.
    I did try and remove the pullups just to try your suggestion, but the result was the same - no reply or [] which is no devices found
  • @crankshaft said in SHT21D I2C and WIPY2:
    10K pullups
    i do not know this sensor but where you have this pullups?
    on this picture there are no pullups - it have it internally?
    alt text
