    BLE - decoding service UUID
    8 Posts 3 Posters 567 Views 3 Watching
      poesel
      I'm using an ESP32 to offer a service with a 128bit-UUID.
      _HE_TB_UUID = UUID('04500100-39fd-49ec-b565-b5d6dc31b6ae')
      ...= self._ble.gatts_register_services(_SERVICES)
      On the client side is a GPy with the 1.20 firmware. Here I use 'service.uuid()' from https://docs.pycom.io/firmwareapi/pycom/network/bluetooth/gattccservice/
      to read the uuid of the service. I'm getting back this bytes object:
      b’\xae\xb61\xdc\xd6\xb5e\xb5\xecI\xfd9\x00\x01P\x04’
      How can I decode that? The documentation only say '...but for 128-bit long UUIDs the value returned is a bytes object.' I've been through all permutations of struct.unpack but to no avail.
      Thanks!
        jcaron @poesel
        @poesel hat do you actually want to do? Display the UUID in UUID format? Compare it with a known UUID? Something else?
        Note that the bytes object has the bytes reversed if you compare that to the original UUID string. Other than that, it’s just a matter of formatting...
          andreas
          True.
          >>> UUID(bytes=b'\xae\xb61\xdc\xd6\xb5e\xb5\xecI\xfd9\x00\x01P\x04'[::-1])
          P 1 Reply Last reply Reply Quote 1
            poesel @andreas
            @andreas - Hallo Andreas! :)
            Cool thanks, thats it.
            @jcaron - compare it with a known UUID. This is for a non-standard service.
              poesel
              Hmm, sorry. I don't get it. Where do I find the UUID function?
              The only one I can find is the one that reads it via bluetooth. The UUID library is not implemented in Micropython.
                andreas
                @poesel said in BLE - decoding service UUID:
                That's true. I used vanilla Python to demonstrate what @jcaron tried to point out here.
                  poesel
                  FYI this is the function I came up to decode the UUID. Not nice but works. :)
                  def UUIDbytes2UUIDstring(uuid):
                      reverses the bytes of uuid and converts them to a properly formatted UUID string
                      from ubinascii import hexlify
                      tmp = str(hexlify(bytes(reversed(uuid))))[2:34]
                      return tmp[0:8]+'-'+tmp[8:12]+'-'+tmp[12:16]+'-'+tmp[16:20]+'-'+tmp[20:32]
                    andreas
                    Thanks @poesel. We picked that up and wrapped it [1] into two corresponding routines for your convenience:
                    >>> from terkin.network.ble.util import BluetoothUuid
                    >>> BluetoothUuid.from_bytes_le(BluetoothUuid.to_bytes_le('04500100-39fd-49ec-b565-b5d6dc31b6ae'))
                    You will also find some background information about why that happens within the comments. Thanks also to @jmarcelino for uuid2bytes from [2].
                    [1] https://github.com/hiveeyes/hiveeyes-micropython-firmware/blob/a8249fd8e9895623de8047ca2d6478dba1351aa8/terkin/network/ble/util.py
                    [2] https://forum.pycom.io/topic/530/working-with-uuid/2
                    With your input, this post could be even better πŸ’—
