    New WiPy 3 not broadcasting SSID
    6 Posts 3 Posters 354 Views 3 Watching
      ghost_cheeks
      I soldered and plugged in a new WiPy 3 to an expansion board, then updated the firmware. I can access the REPL via serial (windows 10), but it's not broadcasting an SSID. Is there a quick way to check the WLAN settings over serial?
        robert-hh @ghost_cheeks
        @ghost_cheeks The problem is caused by the Pybytes variant of the actual firmware 1.20.1.r1, which changes this documented behavior. You can change that by either:
        • installing the legacy firmware, which is a slightly older version 1.20.0.rc13.
        • creating a file on the WiPy with the name pybytes_config.json and the content:
        {"pybytes_autostart": false}
        • Using one of the firmware packages provided by @andreas on this web site: https://packages.hiveeyes.org/hiveeyes/foss/pycom. These all do not include pybytes and behave as documented.
        G 1 Reply Last reply Reply Quote 3
          ghost_cheeks @robert-hh
          @robert-hh awesome! Thanks, I'll give it a shot.
            joshwantstoknow
            @robert-hh
            Hi Robert, I have the same issue as @ghost_cheeks that my WiPy3 is not broadcasting SSID. The explanation that you provided last year seems sensible to me that it's the firmware that could have caused it.
            I have to first say that I'm a newbie to all these, and might need you to hold my hand through this a little.
            First of all, how do I downgrade the firmware to 1.20.0.rc3 (which is in targ.gz format) for the WiPy? And how do I create a file on the WiPy as you've suggested?
            Your help will be very much appreciated!
            Josh
              robert-hh @joshwantstoknow
              @joshwantstoknow You can use:
              pycom.pybytes_on_boot(False)
              to disable pybytes. Just type these two lines at the REPL prompt. The change is permanent until you change it back and survives power cycles.
              J 1 Reply Last reply Reply Quote 2
                joshwantstoknow @robert-hh
                Thanks so much @robert-hh , that solves my problem!
