    LoPy4 - BMP180 - 'I2C' object has no attribute 'start'
    4 Posts 3 Posters 248 Views 3 Watching
      Christian_M
      I'm new to coding with the pycom modules and tried to set up a BMP180 sensor with the I2C pins.
      For that I used the bmp180.py library from github (https://github.com/micropython-IMU/micropython-bmp180) and a code example that i changed for a simple output of the values.
      I'm using the LoPy4 and an Expansion Board 3.0 with the newest firmware on it.
      When i try to run the code first i get the outpout from the i2c scan and then I get an error:
      I2C setup scan [119] #the output from i2c.scan()
      File "<stdin>", line 14, in <module>
      File "bmp180.py", line 46, in __ init __
      AttributeError: 'I2C' object has no attribute 'start'
      Here the two files I'm using
      bmp180.py
      BMP180-testfile.py
      I couldn't find any soulution what's wrong so I hope to find some help here.
      Thank you!
        svonbentzel
          robert-hh @Christian_M
          @Christian_M You may try the driver which I have adapted for Pycom modules: https://github.com/robert-hh/BMP085_BMP180
            Christian_M @robert-hh
            @robert-hh It's working now with your driver.
            Thank you very much!!!
