    Gpy cannot connect to BLE device
    5 Posts 2 Posters 304 Views 2 Watching
      Skipper90
      i have a problem with my Gpy.
      I used the example code From https://docs.pycom.io/tutorials/all/ble/.
      from network import Bluetooth
      bt = Bluetooth()
      bt.start_scan(-1)
        adv = bt.get_adv()
        if adv and bt.resolve_adv_data(adv.data, Bluetooth.ADV_NAME_CMPL) == 'Heartrate':
            print('gefunden')
            bt.stop_scan()
            try:
                print(adv.mac)
                conn = bt.connect(adv.mac)
                #bt.connect(b'\xDA\x0F\xA2\x69\x63\xCA')
                print('verbunden')
                services = conn.services()
                for service in services:
                    time.sleep(0.050)
                    if type(service.uuid()) == bytes:
                        print('Reading chars from service = {}'.format(service.uuid()))
                        print('Reading chars from service = %x' % service.uuid())
                    chars = service.characteristics()
                    for char in chars:
                        if (char.properties() & Bluetooth.PROP_READ):
                            print('char {} value = {}'.format(char.uuid(), char.read()))
                conn.disconnect()
                break
            except:
                pass
            time.sleep(0.050)
      Uploading project (main folder)...
      Not safe booting, disabled in settings
      Reading file status
      [1/1] Writing file main.py (1kb)
      OKets Jun  8 2016 00:22:57
      rst:0x7 (TG0WDT_SYS_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
      configsip: 0, SPIWP:0xee
      mode:DIO, clock div:1
      load:0x3fff8020,len:8
      load:0x3fff8028,len:2136
      load:0x4009fa00,len:19880
      entry 0x400a05d0
      Smart Provisioning started in the background
      See https://docs.pycom.io/smart for details
      gefunden
      b'\xcc\x80\x91J\xfb\x8d'
      after the print of the mac adresse nothing happen...
      The BLE device work, with NRF Connect its possible to connect and look the services.
      Greetings
        sandris
        Hi, you could try to print the exception to get a better understanding of why it's failing.
        except Exception as e:
            print("Failed: " + str(e))
          Skipper90
          So now this is printed.
          Failed: connection refused
            Skipper90 @sandris
            Thank you for your help.
            Now i searched in the forum an finde a post
            ble-connection-issue
            my issue is very embarrassing.... my Phone with the NRF app blocked the connection while scanning...
              Skipper90
              I don´t know what is wrong...
              Now it doesn´t work.
              i is nit possible to connect. every time 'connection refused'
              I have no idea what i am doing wrong.
