    Gateway doesn't send LoRa Wan packets after deep sleep
    Scheduled Pinned Locked Moved Projects
    11 Posts 3 Posters 553 Views 4 Watching
      gaet
      Hi everybody,
      I'm using The Things Indoor gateway to transfer data to my application in TTN. It works well when used in a loop, I can send every packets that I want, the counter increments well and everything. But, when I use deep sleep on my Lopy4 it seems like my gateway doesn't see the packets even if it did transfer the first. I have read almost every topic about deep sleep when using LoRa Wan but none of the solutions is working for me. I am using lora.nvram_save() and restore functions.
      Here is my code for you to have a look :
      #*****			INITIALISATION
      #     			IMPORTS / INCLUDE
      from network import LoRa
      from machine import Pin
      import binascii
      import dht
      #     			DEFINITION DES CONSTANTES
      #     			FONCTIONS COMMUNES QUI SERONT APPELEES
      pycom.wifi_on_boot(False) #pour eviter crash
      #*****			CONFIGURATION
      #     			INSTANCIATIONS
      th  = dht.DTH(Pin('P22', mode=Pin.OPEN_DRAIN),1)
      # initialize LoRa in LORAWAN mode.
      # Asia = LoRa.AS923
      # Australia = LoRa.AU915
      # Europe = LoRa.EU868
      # United States = LoRa.US915
      #SF=[7;12] répartir les SF entre les capteurs
      LORA_NODE_DR = 4
      if machine.reset_cause() == machine.DEEPSLEEP_RESET:
          lora = LoRa(mode=LoRa.LORAWAN, region=LoRa.EU868,sf=8,bandwidth=LoRa.BW_125KHZ)
          lora.nvram_restore()
          while not lora.has_joined():
              time.sleep(4)
              print("Trying to reconnect after deep sleep")
          print("join not first time")
          s.setsockopt(socket.SOL_LORA, socket.SO_DR, LORA_NODE_DR)
          s.setblocking(False)
          #s.bind(2)
          app_eui = binascii.unhexlify('XXXXXXXXXXXXXXXXX') #unique pour l'application
          app_key = binascii.unhexlify('XXXXXXXXXX') #a changer pour chaque capteur
          lora.join(activation=LoRa.OTAA, auth=(app_eui, app_key), timeout=0) # join a network using OTAA (Over the Air Activation)
          while not lora.has_joined():    # wait until the module has joined the network
              time.sleep(4)
              print("not joined yet first time")
      # set the 3 default channels to the same frequency (must be before sending the OTAA join request)
      lora.add_channel(0, frequency=868100000, dr_min=0, dr_max=5)
      lora.add_channel(1, frequency=868100000, dr_min=0, dr_max=5)
      lora.add_channel(2, frequency=868100000, dr_min=0, dr_max=5)
      # remove all the non-default channels
      for i in range(3, 16):
          lora.remove_channel(i)
      #*****			BOUCLE PRINCIPALE
      def run():
          #result = th.read()
          #s.send(str(result.temperature))
          s.send("Yo")
          pycom.rgbled(0xff00) #led verte après envoi de message
          time.sleep(0.4)
          pycom.rgbled(0x0000)
          data = s.recv(64)
          print(data)
          return 0
      run()
      #reset au bout de 20 sec
      lora.nvram_save()
      machine.deepsleep(20000)
      I feel like i've tried everything but can't figure out what's wrong.
      Here is a look at the traffic going through my gateway i TTN, we can see that the first packet is received but then nothing...
      Thanks in advance and have a great day
        robert-hh @gaet
        @gaet I made the experience that the LoRa needs a power cycle to recover. machine.deepsleep() does not power-cycle the board. If you have a Pycom expansion board of any type, you could try pycoproc.go_to_sleep(), which switches off the LoPy4 power.
        G rcolisteteR 3 Replies Last reply Reply Quote 1
          gaet @robert-hh
          @robert-hh I thought this library was only working with PySense or PyTrack but not with expansion board V3.1 ?
          Thank you for your answer
            robert-hh @gaet
            @gaet I have no pyboard 3.x, so I cannot test. And teher is no technical information available for the boards. But it uses the same PIC chip as the other boards.
              gaet @robert-hh
              @robert-hh I just tried with a PySense and py.go_to_sleep() instead of machine.deepsleep(), but the result is still the same, no packet is transfered by my gateway after the deep sleep
                gaet
                UPDATE :
                I used an other Lopy4 and it works fine... The counter is reseting though but it works.
                  robert-hh @gaet
                  @gaet Do the two models have the same firmware?
                    gaet @robert-hh
                    @robert-hh Yeah they have the same firmware, the only thing I think I changed is the pin of the sensor, I switceh from P3 to P4, but I don't see why the first would have caused issue according to the pinout.
                      robert-hh @gaet
                      @gaet P4 can be used unless you have an SD card inserted.
                        gaet @robert-hh
                        @robert-hh I tried my code with all the lopy I had and P4, and it works well with all except with the first, I've updated his firmware but the data sent after deep sleep never arrive
                        • rcolisteteR Offline
                          rcolistete @robert-hh
                          @robert-hh Not Expansion Board v2.x, which doesn't have the PIC microcontroller.
