Network card not available on Lopy
Re: OSError: Network card not available
I am getting the same error as the referenced thread, but I just cannot seem to find what I'm doing wrong here. I'm using a Lopy and I'm simply trying to do a get request to an url just for testing. Here is my boot.py:
from machine import UART import machine import os uart = UART(0, baudrate=115200) os.dupterm(uart) machine.main('main.py').. and here's my main:
from network import WLAN import urequests as requests import machine import time SSID = 'Altibox099473' PASSWORD = 'SeKmLeMk' wlan = WLAN(mode=WLAN.STA) wlan.antenna(WLAN.INT_ANT) # Assign your Wi-Fi credentials wlan.connect(SSID, auth=(WLAN.WPA2, PASSWORD), timeout=5000) while not wlan.isconnected (): machine.idle() print("Connected to Wifi\n") try: res = requests.get("https://jsonplaceholder.typicode.com/todos/1") print(res) pass except Exception as e: print("Request failed: " + str(e)) passI'm using urequests found here: https://github.com/jotathebest/micropython-lib/blob/master/urequests/urequests.py
Really appreciate some help. Thanks!
Ok I finally got this to work! I was using the pycom fw upgrade tool tol flash my device with what I thought was the latest fw. Flashed my device with version 1.18.0 and it worked like a charm (latest version did not work, giving me another error..)
Why doesn't the firmware update tool flash the latest version?
