    Lopy over Lopy by Lora
    7 Posts 2 Posters 225 Views 2 Watching
    • W Offline
      Wolli01
      I am trying to connect Lopy over Lopy by Lora using the example.
      https://docs.pycom.io/tutorials/lora/lora-mac/
      But this also only works at a very small distance, i.e. only when they are next to each other. If I walk 1 meter away from it, it won't work anymore. Both have a connected antenna.
      Software Pycom MicroPython 1.18.3 [v1.8.6-849-e0915e1]
      on 2019-10-06; LoPy4 with ESP32
      Does anyone know what could be the cause?
      Translated with www.DeepL.com/Translator (free version)
        robert-hh @Wolli01
        @Wolli01 I have more the opposite problem, that at short distance the signal levels are too high. So when doing that, I uses a 50 Ohm termination resistor instead of an antenna. The stray radiation from the board & the pigtail cable is still strong enough for lab desk testing. If you have LoPy4, check that you use the right antenna plug. They are different for 433 and 868/915 MHz.
        You problem may have another cause: I found the Lopy-Lopy sample code not very reliable. And you have to take care to give both devices a fresh power-up start. Soft reboot does not initialize the Lora modem properly.
        W 1 Reply Last reply Reply Quote 0
        • W Offline
          Wolli01 @robert-hh
          @robert-hh
          In a normal Lorawan via a gateway, the two Lopy4s work perfectly. How long can the transmission text be?
          What is 64 for with s.recv(64)
            robert-hh @Wolli01
            @Wolli01 receive up to 64 bytes.
            • W Offline
              Wolli01
              I have now taken a brand new Lopy4, but the problem is always the same. On a short distance it works but from 1 meter on no more data comes.
              Is there a Lopy to Lopy code that works in any case?
              Do you actually not have to enter an identification?
              What is another Lopy from any other Lopy comes into play then I receive unintentionally also its data or?
                robert-hh @Wolli01
                @Wolli01 What I am missing in the example you pointed at is to set the frequency. The sample scripts I use set it specifically, like:
                lora = LoRa(mode=LoRa.LORA, frequency=868000000, region=LoRa.EU868)
                If two devices do not work at the same channel, there may still be some spurious reception on an adjacent channel.
                • W Offline
                  Wolli01
                  Found the error, I had chosen the wrong antenna site. Now it works.
                  Thanks for the food for thought.
