    mqtt on/off message on button press
    Scheduled Pinned Locked Moved Projects
    2 Posts 2 Posters 242 Views 2 Watching
      jupiter8
      for those who searched and need a simple sketch on how to send an ON/OFF MQTT message with a switch here it is:
      Based on a GPY, commented are for WIFI, use accordingly.
      enjoy.
      from network import LTE
      from machine import Pin
      from umqtt import MQTTClient
      is_pressed = False
      button = Pin("P10", mode=Pin.IN, pull=Pin.PULL_UP)
      def settimeout(duration):
           pass
      lte = LTE()
       # Modem does not connect successfully without first being reset.
      print("Resetting LTE modem ... ", end='')
      lte.send_at_cmd('AT^RESET')
      print("OK")
      print("Configuring LTE ", end='')
      lte.send_at_cmd('AT+CGDCONT=1,"IP","yourAPN"')
      print(".", end='')
      lte.send_at_cmd('AT!="RRC::addscanfreq band=2, 4, 5 dl-earfcn=9410"')
      print(".", end='')
      lte.send_at_cmd('AT+CFUN=1')
      print(" OK")
      if not lte.isattached():
          print("Attaching to LTE network ", end='')
          lte.attach()
          while(True):
              if lte.isattached():
                  print(" OK")
                  break
              print('.', end='')
          # Once attached, connect() should succeed.
          if not lte.isconnected():
              print("Connecting on LTE network ", end='')
              lte.connect()
              while(True):
                  if lte.isconnected():
                      print(" OK")
                      break
                  print('.', end='')
      lte.connect()
      while not lte.isconnected():
          machine.idle()
      print("Connected to LTE\n")
      #wlan = WLAN(mode=WLAN.STA)
      #wlan.antenna(WLAN.EXT_ANT)
      #wlan.connect("yourwifi", auth=(WLAN.WPA2, "yourpass"), timeout=5000)
      #while not wlan.isconnected():
      #print("Connected to Wifi\n")
      client = MQTTClient("joe", "yourMQTTbroker", port=1883)
      client.settimeout = settimeout
      client.connect()
          if button() == 1 and not is_pressed:
          elif button() == 0 and not is_pressed:
              print("Button pressed")
              print("Sending ON")
              client.publish("/gpy", "ON")
              is_pressed = True
          elif button() == 1 and is_pressed:
              print("Button released")
              print("Sending OFF")
              client.publish("/gpy", "OFF")
              is_pressed = False
              pass
      C 1 Reply Last reply Reply Quote 2
        Clyde Bess @jupiter8
        @jupiter8 thx for your code :)
        This is what I was looking for.
        Is there a way to disconnect Lte to save power and only power up to send the message?
        I did some adjustments to check connectivity but I can’t break
        the loop.. so the Message is send again after a undefined period of time..
        Next thing: the program exit on error 104 if the button debounce (reed contact)
        Awesome would be something like:
        In deepsleep wait for interrupt - if interrupted by button
        Connect to lte > publish actual state of button/reed ( door locked / door unlocked & door closed / door open) + Rtc and battery (ok / low/ warning) > disconnect Lte > deepsleep. > wait for interrupt.
        Is this easy to develop or never can be handled by an newbie??
        Kind regards
