    I2C output binary to integer
    3 Posts 2 Posters 230 Views 2 Watching
    • V Offline
      Vin883
      Hi all,
      I"m communicating between a Sipy and and Microchip dsPic in slave mode.
      Bytes received by Sipy appear to be (see picture below) in binary format.
      Bytes sent by dsPIC: 0x05 and 0x42.
      This data is displayed in the console as b'\x05' and b'B'
      How could I convert this data in integers? Sorry I'm a micropython beginner!
      • E Offline
        Eric73
        @Vin883 said in I2C output binary to integer:
        Convert for print output or to compute with integer instead of bytes() ?
        For print in hexa:
        print("{0:x} {1:x}".format(bytereceipt2[0],bytereceipt2[1]))
        For decimal replace :x by :d
        For computing int value you must use
        Val=struct.unpack("B",bytereceipt2[0])
        Val=Val[0]
        V 1 Reply Last reply Reply Quote 0
        • V Offline
          Vin883 @Eric73
          @Eric73 Thanks a lot!!
          Yes, goal is to compute int values instead of bytes.
