[lopy4] no WiFi on startup
Inspite of the blue heartbeat, there is no WiFi AP after starting the lopy4 device.
- I successfully erased flash using
esptool.py erase_flashand later successfully updated the firmware to1.16.1using thepycom firmware update toolon Ubuntu 18.04. - I used a USB UART Serial device on port
/dev/ttyUSB0 (Slilicon Labs)to erase flash and update firmware on the lopy4. - When I use
miniterm.py, I can see the python terminal and can execute basic commands like changing led colors.
Below is the print I see on bootup
ets Jun 8 2016 00:22:57 rst:0x1 (POWERON_RESET),boot:0x12 (SPI_FAST_FLASH_BOOT) configsip: 0, SPIWP:0xee clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 mode:DIO, clock div:1 load:0x3fff8020,len:8 load:0x3fff8028,len:2136 load:0x4009fa00,len:19880 entry 0x400a05d0 Smart Provisioning started in the background See https://docs.pycom.io/smart for details Pycom MicroPython 1.20.1.r2 [v1.11-06dfad0] on 2019-11-30; LoPy4 with ESP32 Pybytes Version: 1.3.0 Type "help()" for more information.This leaves no option but to type out each python command on the terminal, rather than using easier ways of
ftpand usingpymakr VScodefor uploading code to the lopy4. Also, to be clear: I do not posses any expansion board/Pytrack/Pysense/Pyscan device and have been using a usb-serial-uart module for formatting, upgrading firmware or uploading code.I read on https://forum.pycom.io/topic/5338/no-lopy-4-wifi-after-updating-the-firmware about similar problems of not having WiFi AP on update, but wanted to verify if it was solved. My final objective would be to try out the
pymesh LoRaon two/three modules of lopy4.Apologies if the this was posted against the rules of the forum.
Hi! I am having the same problem, did you somehow get it working?
@nilay994 This could by cause by pybytes, which started. You should be able to stop that with:
import pycom pycom.pybytes_on_boot(False)And then reboot. The setting is permanent. If that does not work, create a file on your device called pybytes_config.json and the content:
{"pybytes_autostart": false} -
@robert-hh but then you wont be able to add your device to pybytes right?
@Ph0333nix right. Can't you connect your device in STA mode?
@robert-hh said in [lopy4] no WiFi on startup:
STA
I am completly new to this, so I am not sure what that is. I will look at the documentation and see what I learn, thanks for your response! :)
@Ph0333nix In STA = station mode, the board connects to your local router as client.
@robert-hh I will attempt to do so, thank you for the help!
