    TX_FAILED_EVENT not triggered
    lorawanlopy4
    2 Posts 1 Posters 224 Views 1 Watching
    • B Offline
      berryskies
      Hi everyone.
      I have setup my lora.callback to to handle TX_FAILED_EVENT trigger as per examples on Pycom site. I have been trying to test using following method.
      1. Send command to lopy4 to uplink data to server (this works fine). I have set socket to uplink confirmed messages.
      2. I have set a delay of 15 seconds from receiving command to send uplink and beginning transmission.
      3. After seeing on the serial console that node has received command I pull the plug on my gateway before node starts transmitting.
      4. I expect to see that TX_FAILED_EVENT event is triggered as node will not receive any ACK from server. However it appears the event is never triggered evidenced by no messages printed to console from theTX_FAILED_EVENT.
      Here is the event code below.
      if events & LoRa.TX_FAILED_EVENT:
              print("TX Failed. ACK not received after 1 retries")
              print("Reset")
              pycom.rgbled(0xFFFFFF)
              lora.nvram_erase()      # this should force a rejoin of network
              time.sleep(2.5)
              machine.reset()         # TX failed so try and rejoin network by resetting
      Any help gratefully received.
      Alan
      • B Offline
        berryskies @berryskies
        @berryskies My bad! Stupid error (as usual?). I misread the socket.SO_CONFIRMED option. I thought this was a constant boolean and didn't set the trailing 0 to 1 (slap to forehead). All working as expected.
