    Using Adafruit's PIR Sensor
    1 Posts 1 Posters 106 Views 1 Watching
    • techykermitT Offline
      techykermit
      I just wrote this in another topic:
      "I have a bunch of PyComs lying around and I tested this with one of my devices and Adafruit's PIR sensor. Worked fantastically"
      Sadly, it turns out that this is not the case.
      Here is what I have:
      I have a PIR sensor from Adafruit that I can read from with this code:
      def read_pir(): #Function for reading status from the PIR device
          pir = Pin("P2", mode=Pin.IN, pull=Pin.PULL_UP)
          if pir() == 1: #If the PIR sensor is detecting any motion
              motion = True
          else: #If the PIR sensor is not detecting any motion
              motion = False
          return motion #Return the read values
      However, what I need to do next is to make my PyCom wake up from deepsleep every time the sensor detects motion. I have tried this code:
      pir = machine.Pin("P2", mode=Pin.IN, pull=Pin.PULL_UP)
      machine.pin_sleep_wakeup((pir,), mode=machine.WAKEUP_ANY_HIGH, enable_pull=True)
      I have also tried:
      machine.pin_sleep_wakeup(["P2"], mode=machine.WAKEUP_ANY_HIGH, enable_pull=True)
      But what I find strange is that (even if nothing is connected to P2), it wakes up from deepsleep immediately after I put it in deepsleep. That is obviously not the expected behaviour, I want the device to sleep until the sensor detects any motion.
      What happens is that when I run this code:
      from machine import Pin
      machine.deepsleep(10000000)
      The device restarts with a DEEPSLEEP_RESET immediately after I run the file, and like I said, this happens even when nothing isn't connected to the pin.
      Is there any way I can solve this?
