    Pytrack deepsleep wakeup on pin problems
    2 Posts 2 Posters 170 Views 2 Watching
      Peter Ehses
      I'm trying to have my GPy on a Pytrack wake up from deepsleep once the onboard button is pushed.
      I'm trying to use the pycoproc deepsleep function as this gives me a lower sleep current.
      I'm neither able to use the P14 on board button nor the P9 "INT Pin" to wakeup.
      What is a known hardware setup to get the Pycom pin wakeup working?
      Is there any way to use an existing button (GPy reset or P14) instead of a new one?
      Alternatively, how do I disable all Pytrack chips without turning the GPy's power off so I can sleep it separately?
      -Edit-
      The exact problem apart from no real documentation on how to set the INT pin up is that I have another device on Pin 9 and would like to get around undoing that whole thing.
      (I'm using P9, P10, P11, P18, P19, P20 for an e paper display)
      With machine.deepsleep() and every radio disabled I get about ~30mA current draw. With the same code on an Expansion board instead of a Pytrack I get ~500uA, With py.go_to_sleep() I get either ~6mA (probably due to a problematic wakeup pin config / setup) or <150uA (which is expected because of my peripherals and OK-ish) with no real pattern.
      I am using this to turn off GPS and
      self.lte.disconnect()
      self.lte.detach()
      self.lte.send_at_cmd('AT!="CBE::powerOff"')
      self.lte.deinit()
      to turn the LTE as off as possible.
      my boot.py is
      import network
      import gc
      import os
      bt = network.Bluetooth()
      bt.deinit()
      ap = network.WLAN()
      ap.deinit()
      server = network.Server()
      server.deinit()
      gc.enable()
      which should cover all bases.
      To try the Pytrack deepsleep with Pin Wakeup I've tried
      py.setup_int_wake_up(False, False)
      py.setup_int_pin_wake_up(False)
      py.setup_sleep(20)
      py.go_to_sleep(False)
      which does nothing when jumping P#9 to either GND ore 3V3.
      The timed restart is also so-so as it sometimes doesn't restart after my 20s but instead after a minute, 5 or never.
        jcaron @Peter Ehses
        @Peter-Ehses The whole Pytrack/Pysense wake-on-pin is a bit of a mess in my experience, but you can make it work.
        The trick is to cut (or somehow isolate) P9 on the *Py module. Otherwise you'll get all sorts of weird behaviour because P9 is (indirectly) pulled low during Pytrack/Pysense-controlled deep sleep.
        The right order for the calls on a Pysense is (or was, the last time I played with that):
                  py.setup_sleep(SLEEP)
                  py.setup_int_pin_wake_up(not p)
                  py.go_to_sleep()
        (here p is the current state of the pin, so it dictates whether we want to wake up on falling or rising edge)
        Don't quite remember where the setup_int_wake_up call fits (didn't use it in my case), but most likely after the setup_sleep.
        See previous discussions on this topic:
        https://forum.pycom.io/topic/2829/pysense-external-wakeup-pin-p9-is-pulled-low-when-in-deepsleep
        https://forum.pycom.io/topic/1673/pysense-pinout-wake-on-pin
