    New Firmware Release 1.20.2.rc3
    14 Posts 6 Posters 867 Views 6 Watching
    • X Offline
      Xykon administrators
      A new firmware release 1.20.2.rc2 1.20.2.rc3 is now available. Even though this is marked as a release candidate, we think it's significantly more stable than the previous release which is why it's available in the standard pybytes category. Furthermore we have added a flag to disable the built-in pybytes code.
      pycom.pybytes_on_boot(False)
      A new firmware updater will be released shortly that will allow setting this during the upgrade.
      The full release notes can be found here: https://github.com/pycom/pycom-micropython-sigfox/releases/tag/v1.20.2.rc2 and and the elf files for rc3 here: https://github.com/pycom/pycom-micropython-sigfox/releases/tag/v1.20.2.rc3
      Christian Ehlers
      robert-hhR J securigyS 4 Replies Last reply Reply Quote 1
        robert-hh @Xykon
        @Xykon If built without pybytes, there is no pybytes_on_boot() method in the modukle pycom, but an error message comes up:
        could not find module '_main_pybytes.py'
        That was already mentioned before. It looks like the trouble is here:
                if (config_get_pybytes_autostart()) {
                    pyexec_frozen_module("_main_pybytes.py");
                } else {
                    pyexec_frozen_module("_main.py");
        config_get_pybytes_autostart() seems to return True, even if it was never enabled. And since the method pybytes_on_boot() does not exist, it cannot be disabled,
          jcaron @Xykon
          @Xykon Can you please make sure that docs are updated, and where necessary, that they mention in which version things changed? E.g. the BLE callback.
          • X Offline
            Xykon administrators @robert-hh
            @robert-hh said in New Firmware Release 1.20.2.rc2:
                    } else {
            An update will be available shortly (1.20.2.rc3) which fixes that. It's already on GitHub in the Dev branch.
            Edit: The pybytes_on_boot() function is not exposed unless you build the pybytes variant.
            Christian Ehlers
              robert-hh @Xykon
              @Xykon Thanks. I confirm it's fixed.
              I've seen that, and it's consistent.
                peterp
                1.20.2.rc3 has just been released and rc2 has been removed. Please update
                  robert-hh @Xykon
                  @Xykon @iwahdan just published v1.20.0.rc13. That is confusing. What is the relation between v1.20.2rc3 and v1.20.0rc13?
                  • X Offline
                    @robert-hh said in New Firmware Release 1.20.2.rc3:
                    It was an old draft that hadn't been published before. We considered deleting it but for consistency we just decided to publish that release in case anyone still needs the elf files for debugging.
                    Christian Ehlers
                    • K Offline
                      kjm @Xykon
                      @Xykon I'm familiar with updater.elf but not application.elf Can someone please like me to some docs that explain how to use application.elf for debugging pls?
                      • securigyS Offline
                        securigy @Xykon
                        @Xykon Why everything is always so complicated? What are .elf files? Is that just for pros?
                        Why can't it be just one file as before that you load into Firmware upgrade tool?
                          peterp @securigy
                          @securigy said in New Firmware Release 1.20.2.rc3:
                          @securigy Let's take a step back. I don't think it actually is complicated. If you use Firmware upgrade tool, you should get 1.20.2.rc3. Please try (again).
                            robert-hh @peterp
                            @peterp I guess, what people are missing are the tarballs of the most recent firmware packages, like the ones placed in here: https://software.pycom.io/downloads/FiPy etc.. That was promised once, and worked for a short time.
                            That can be used for scripted device update, which is preferable if you update more than one device. Obviously, elf-files contain everything and can be used together with esptool.py and the build scripts to create such a tarball. But having the "official" tarballs available is preferred.
                            I'm not arguing against the elf files. If you want to debug the firmware, they are needed. But most people don't do that. They expect Pycom to do it.
                            • X Offline
                              You can temporarily use the links below to download Pybytes firmware files.
                              • WiPy
                              • LoPy
                              • SiPy
                              • GPy
                              • FiPy
                              • LoPy4
                              Christian Ehlers
                                robert-hh @Xykon
                                @Xykon Thanks.
