    FiPy + Expansion Board: Battery Question
    24 Posts 4 Posters 754 Views 4 Watching
    • securigyS Offline
      securigy
      I am having FiPy v1.2 sitting on Expansion Board v3.1 and connection to GNSS development board via I2C and 3V3 and GND. How do I know what battery I need? How do I know if 3.7V Li-Ion battery with 2000 mAh be enough?
      My GNSS dev board consumes 25 mA at acquisition and 22 mA at tracking (1 uA at standby).
      More importantly, I read in Expansion Board documentation:
      To use the battery, pull P8/G15 high (connect to 3v3). If you want to use the SD card as well, use a 10k pull-up.
      Can anybody explain to me what are they referring to? (Pull p8/G15 high). Do they really mean that I have to connect this pin to 3V3 pin?
        robert-hh @securigy
        @securigy said in FiPy + Expansion Board: Battery Question:
        As far as I remember, that was a problem with the expansion board 3.0. In the expansion board 3.1, this resistor should be present.
        The 2000 mAh battery should be able to supply sufficient current and last about 8 hours net runtime. The FiPy I have hear consume ~100 mA when idle, ~200mA with LTE enabled with short peaks of >300mA.
        J securigyS 2 Replies Last reply Reply Quote 0
          jcaron @robert-hh
          @robert-hh Wow, does the FiPy draw that much more than the LoPy? IIRC the LoPy was closer to 50 mA.
          Of course, it probably all depends whether WiFi and/or BLE are on and what they are actually doing (connected, scanning...)
          But at 100-200 mA, getting decent battery life with a deep sleep pattern really needs having the shortest "awake" time (and long deep sleep periods).
            robert-hh @jcaron
            @jcaron I made a little diagram of the current consumption from startup, starting LTE modem, connect, some traffic and disconnect. The figure is A. I used an INA219 and a Schottky diode as a poor man's log type shunt. That causes the falling ramp between ~17000 and 20000. Not precise, but doing that I have a extremely wide range from µA to A, but low resolution.
              andreas
              Hi there,
              while this is a little bit OT in this very context, I wanted to share a conversation within our community with you [1]. They measure power consumption of a TTGO T-Call there which integrates an ESP32 with a SIM800.
              With kind regards,
              Andreas.
              [1] https://community.hiveeyes.org/t/minimal-hardware-design-gsm-stockwaage-mit-ttgo-t-call/2906/51
              • securigyS Offline
                securigy @robert-hh
                @robert-hh 8 hours... That's pretty bad. It is suddenly a critical issue for me that may prevent coming up with ANY portable solution using FiPy... So if I want to produce some kind of prototype/POC package in a standard Pycase box that last for 10 days then I need 72000mAh power bank which does not exist. The biggest are 30000 mAh and are very heavy and bulky relatively to Pycase... The 72000 mAh is based on 300 mA constant consumption which of course might not be the case... Whell, that means I have to invest more time in measuring and calculating and deep sleep...
                So, here are the questions of non-EE guy:
                1. How do I measure the current consumption with multimeter? (I know benign question for mid-schooler) connecting multimeter to 3V3 and GND on the Expansion Board 3.1 ?
                2. Provided I have GNSS dev board connected with 3V3 and GND wires to 3V3 and GND pins on FiPy how do I measure total current consumption?
                3. Somewhere on this forum I saw following code. Is it conceptually the right thing to do in order to disable all other "unnecessary" services?
                4. Can anybody recommend high-density flat battery that will fit into Pycase?
                import network
                import os
                from network import LTE
                from network import WLAN
                from network import Bluetooth
                from network import LoRa
                # setup as a station
                lte = LTE()
                print("Line 15")
                lte.send_at_cmd('AT+CFUN=0')
                lte.send_at_cmd('AT!="clearscanconfig"')
                lte.send_at_cmd('AT!="addscanfreq band=28 dl-earfcn=9410"')
                lte.send_at_cmd('AT+CGDCONT=1, "IP", "telstra.internet"')
                lte.send_at_cmd('AT+CFUN=1')
                while not lte.isattached():
                    print("Attaching...")
                    time.sleep(0.1)
                print("Attached")
                lte.connect()
                while not lte.isconnected():
                    print("Connecting...")
                    time.sleep(0.1)
                print("Connected!")
                time.sleep(2)
                quit = False
                while quit == False:
                    try:
                        lte.deinit()
                    except OSError:
                        print('  Exception occured, retrying...')
                        pass
                        quit = True
                print("Disconnected")
                print('Switching off WLAN')
                wlan = network.WLAN()
                wlan.deinit()
                print('Switching off Heartbeat')
                pycom.rgbled(0x000000)
                print('Switching off Server')
                server = network.Server()
                server.deinit()
                print('Switching off Bluetooth')
                bt = Bluetooth()
                bt.deinit()
                print('Switching off LoRa')
                lora = LoRa(mode=LoRa.LORAWAN, region=LoRa.AU915, power_mode=LoRa.SLEEP)
                print("Going to sleep")
                machine.deepsleep(300000)
                  robert-hh @securigy
                  @securigy The answer for supply is: do not run the device all the time. Set it to deep sleep when not needed. Then the power consumption is in the range of µA instead of mA.
                  Yes, you measure the current consumption with a multimeter.
                  Voltage is measure between 3V3 and GND. For measuring current you measure the wire through the + line of the battery.
                  For measuring the consumption on the USB connector there are convenient Adapters which you just plug in between. The only downside of these adapters is, that they do not have a µA resolution.
                  securigyS 1 Reply Last reply Reply Quote 0
                  • securigyS Offline
                    securigy @robert-hh
                    @robert-hh The first this I started researching is how much current my whole assembly consumes... and I found the USB adapter that measures micro Amperes, or at least it says it does: (TC66 USB Tester)
                    https://www.amazon.com/gp/product/B07NXRPNPR/ref=ox_sc_act_title_1?smid=A1NOQTMMT39TJ0&psc=1
                      robert-hh @securigy
                      @securigy This current adapter is definitely the one on the market with the best resolution. The last digit shows 10µA resolution. So you can tell whther the current consumption is below 100µA. How precise that is, is to be determined.
                      When you use such a device, please bear in mind that due to the switching voltage regulator of the FiPy the current consumption at 3.7 V is higher than at 5V. The energy consumed (Voltage * Current) is about the same. So if the device takes 100mA at 5V, it will take ~130mA at 3.7 V.
                      robert-hhR securigyS 2 Replies Last reply Reply Quote 0
                        robert-hh @robert-hh
                        @robert-hh I took your script, modified it a little bit for my LTE place and recorded the current and charge in As. Diagram below. The total charge consumed was ~7 As at 5V -> Energy 35 Ws. At 2000mAh battery with nominal voltage has about 2 * 3.7 * 3600 = 26600 Ws. That means, that you can run about 750 of these cycles. If you run them every 5 Minutes + 1 Minutes operation time, that give a time of 4560 minutes or 76 hours (~3 days).
                        securigyS 2 Replies Last reply Reply Quote 1
                        • securigyS Offline
                          securigy @robert-hh
                          @robert-hh Couple of questions:
                          1. Does your or jcaron's chart include disabling all other services/networks like BLE, WiFi, LoRa, etc...
                          2. How do you produce this chart in the first place? tools? library?
                          3. Are you measuring the USB input or specific wires?
                            robert-hh @securigy
                            @securigy
                            ad 1: I used the script you posted below. I replaced only lines 16-20 with a single line: "lte.attach(....)"
                            ad 2: I have a setup, where I measure the current using a INA219 breakout in the USB Vcc wire. I take a measurement every ~100ms, and print a ms timestamp and the current, which is logged into a text file. Then I import the text file into OO calc (like Excel), do the corrections of current and time offset. For every measurement I caculate the current * time_step, which gives an charge item, which is cumulated (integrated) into charge over time. Pretty basic.
                            ad 3: I measure the USB. But since I calculate the energy needed, that one is about the same for the battery connection. As part of the data correction, I subtracted the current used by the USB/UART adapter.
                            Some aspects have been found and criticized by other too, as you can find in this forum;
                            • The fipy takes some time to start and start-up the modem.
                            • Attaching after a cold boot takes considerably long. In the figure above this startup phase takes about 25 seconds. Other LTE modems are ready and attached within a few seconds.
                            • At about 42 seconds deepsleep() is called. Then it takes about 5 seconds with a short current burst until the device really sleeps. There may be problems with the LTE modem if you shut off power before this cycle ended. The Expansion board support a deepsleep method of cutting power to the xxPy device. While this results in the lowest current consumption, there seem to be side effects.
                              jcaron @robert-hh
                              @robert-hh I don’t have a FiPy of GPy, but I wonder what became of the PSM/eDRX management in the modem? It’s supposed to provide a much quicker reconnection but I think there were still lingering issues last time this was discussed.
                                robert-hh @jcaron
                                @jcaron I did not follow that discussion either. But there seem to be no result. Maybe the new modem hardware works better in that aspect too.
                                • securigyS Offline
                                  securigy @robert-hh
                                  *@robert-hh With regards to DeepSleep:
                                  I read some postings on the subject, including yours:
                                  jcaron Nov 30, 2018, 2:43 PM
                                  @james-matthews just to clarify, deep sleep achieves very low power consumption by powering down nearly everything on the chip, including the cores and all associated state (registers) and RAM.
                                  So once it exists deep sleep, it doesn't remember a thing, and it has to start from scratch again, so you need to maintain any state you need across sleep in long-term storage (if you need any state at all).
                                  robert-hh Nov 30, 2018, 4:16 AM
                                  @james-matthews when the device wakes up from machine.deepsleep(), runs through the reset stages. So you cannot simply put deepsleep() into a loop like you would do with sleep(). Before deepsleep() you have to save your execution stage, after reset check the reset cause, and then resume the state you code had before deepsleep().
                                  nespressif Nov 30, 2018, 3:42 AM
                                  Hello @james-matthews , I don't know exactly what you want to do, but deep sleep is always used as the last function of the program, that is, you do what you want and as last instruction you put machine.deepsleep(300000). Your code will run and then the module will sleep for 5 minutes, when that time ends will be restarted and run again from the beginning, ie reset.*
                                  I must admit I am bit surprised by this - it is about "reset" do I understand correctly that if I put FiPy into deep sleep of 5 seconds at the end of the code, then after 5 seconds it completely resets like a "reset-button reset" and the execution of my MicroPython script will start from the beginning like loading libraries, and will do all the LTE initialization, lte.attach, I2C setup, and GPS initialization, etc ??
                                  So again surprised to read the "reset" thing and if this is correct that after deep sleep the modem resets and the entire micropython script executes from the beginning (and it indeed takes 30+ sec to init and to attach the LTE modem) and I'd like to deliver GPS reading every few seconds - then the Deep Sleep it is not a viable solution at all... Am I correct?
                                  • securigyS Offline
                                    securigy @robert-hh
                                    @robert-hh I see - I thought initially that there is some add-on in VS Code that produces the chart without all the logging, etc...
                                    • securigyS Offline
                                      securigy @robert-hh
                                      @robert-hh Word of caution - I guess I did not read well enough - just got it from Amazon and it has USB Type C on both ends. So now, I am waiting to USB-Type-C to USB-Micro-B adapters....
                                        robert-hh @securigy
                                        No. But using logging and Excel is not that much work. And since the data has to be corrected anyhow, it is not an additional work.
                                        I considered getting that device, but this USB-C stuff stopped me. The other drawback: It is promising more than it can deliver. The 6 digit display seems to tell, that there is a current resolution of 10 µA. The data specs (https://www.amazon.de/gp/product/B07P2J5VTT?pf_rd_p=8997cce2-05c4-4359-bdb7-10e52332d836&pf_rd_r=Y0QG8QTTX7CEF8YRMEV8&th=1 ) however say, that the error is 0.1% +/- 10 digits (or 0.5% +/- 10 digits for voltage). That means, that the last two digit in the display just shows noise and the real resolution is not better 1mA. That would be OK too, if true. For 6 digits the analog section in the measuring path would require -120dB noise margin, which is a huge challenge. So even from that aspect the specs look too god to be true.
                                        • securigyS Offline
                                          securigy @robert-hh
                                          @robert-hh I resolved Type C with this (arriving tomorrow). 4 adapters for $6.
                                          All this playing with measuring current is great but I still have very principle question that is crucial to my development:
                                          • So far from different posts I understood that once I put FiPy into deep sleep and the timeout expires the FiPy not only does not remember at what stage it was executing but is also is reset and starts the execution of the micropython from the very top. Now, I would not mind that, except that LTE initialization and attach() takes time - could be a lot - 30-45 sec. That means that if I want to push GPS coordinates to the Cloud over LTE-M every few seconds - I cannot since it takes LTE 45 sec to become operational. Is that my imagination or is it correct?
                                            robert-hh @securigy
                                            @securigy Your assumption about the LTE startup times is correct. The ESP alone take 2-3 seconds to boot.
                                            If you want to transfer coordinates every few seconds, then the device has to stay powered. I have here a set-up with an generic ESP32, microypthon.org firmware, and a SIM7020 LTE module. The runtime current consumption is ~50mA. At lightsleep it decreases to ~30 mA, not even trying to let the LTE modem sleep. You might also ask @danielm, who made such a board in an attempt to have a reliable low power LTE solution. I do not know how far he got.
                                            But you have to bear in mind, that the transmission energy does not come for free. So that power peak will always be there. Only startup times and standby current can be tailored.
                                            securigyS 1 Reply Last reply Reply Quote 1
                                            • 1
                                            • 2
                                            • 1 / 2
