    Advice on SDI over WiPy project
    3 Posts 2 Posters 978 Views 2 Watching
    • V Offline
      vidgeek888
      Hi guys, I'm trying to make sdi transceiver module using these sdi fiber extenders , lets say I have SFP module and read sdi stream into memory buffer or array of files, then I would like to send it further with WiPy, will it work with uncompressed sdi streams 500-1500Mbps? If yes, could you please recommend me any related articles/topics with similar applications? I appreciate your help guys, thank you!
        jmarcelino @vidgeek888
        @vidgeek888
        That's WAY above what the WiPy can do, those rates are FPGA territory not microcontroller stuff. I think the maximum the ESP32 can do is 10Mbps on the Ethernet port.
        If you want to stay within Python you could try the PYNQ-Z1 which has a Xilinx Zynq FPGA and ARM combo: http://www.pynq.io
        But be warned that even with Python it's quite a learning curve.
        • V Offline
          vidgeek888
          Thank you for advice! I would probably use Verilog then.
