lopy to raspberry pi serial communication issues
@MusteDaniel it is not the order which changed, there are characters missing. What happens if you reduce the speed to 9600 baud.
@robert-hh in last reply is the output with 9600 baud
Have you switch off WiFi functionality of the Pi3?
Once upon a time the Pi3 had trouble to run serial and WiFi at the same time. I don't know if they were able to fix it by software in the past 2.5 years.
@crumble I deactivate wifi from /boot/config.txt but the output is still in the same manner
Have you:
TX <-> RX
RX <-> TX
gnd <-> gnd -
core fequency has to be set as well:
[https://www.raspberrypi.org/forums/viewtopic.php?t=213499](Link Adresse)
[https://tech.scargill.net/raspberry-pi-3-serial/](Link Adresse) -
@crumble This does not seem to be a frequency or baud rate issue. In that case a lot of other characters would show up. It looks more like two processes fighting for input from the same device. So the posters script only get part of that.
@crumble It looks as if /dev/ttyAMA0 is also used by bluetooth. You could try to disable it.
@robert-hh it s disable
@crumble thanks, i tried...no difference
Imho you problem originates in the use of "read(20)". You could try to send b'33.5|xxxxx|xxx|xxx \n' or after writing r on the lopy you add a uart1.write(chr(13)).
On the Raspi you read rec with rec=ser.readline().
So if one or more chars go missing you don't lose your intended string formatting for the other data.
